G getstuff4less SatelliteGuys Pro Original poster Jul 24, 2009 235 0 CA Apr 6, 2011 #1 I notice it will work on D*. Any experiences?
Peter Parker Formerly Geronimo Supporting Founder Lifetime Supporter Sep 9, 2003 12,375 2,100 Apr 6, 2011 #2 No. I am less sure about the 922.
mike123abc Too many cables Supporting Founder Sep 25, 2003 25,766 5,082 Norman, OK Apr 7, 2011 #3 It works with the 922.
lakebum431 Pub Member / Supporter Pub Member / Supporter Lifetime Supporter Sep 5, 2005 17,141 5,114 Norris, TN Apr 7, 2011 #4 It works very well on the 922, however, since playon is not in HD I don't use it much. Usually only to access ESPN3 events that I want to watch live.
Scott Greczkowski Welcome HOME! Staff member HERE TO HELP YOU! Cutting Edge Sep 7, 2003 103,751 29,575 Newington, CT Apr 7, 2011 #5 No Playon does not work on the 722 as the 722 does not support DLNA. The 922 however works GREAT with PlayOn and really opens the 922 up with what you can watch. (Now only if PlayOn streamed in HD)
G getstuff4less SatelliteGuys Pro Original poster Jul 24, 2009 235 0 CA Apr 8, 2011 #6 Doesn't it have the same chipset as the 922? If that's the case, will it work? I might get this. I need it anyway. Would playon work then?
lakebum431 Pub Member / Supporter Pub Member / Supporter Lifetime Supporter Sep 5, 2005 17,141 5,114 Norris, TN Apr 8, 2011 #7 No, it won't work. It does not work with DNLA right now (which is needed for Playon). If they updated the software maybe it could, but I doubt that happening.
Paradox-SJ SatelliteGuys Pro Nov 20, 2003 1,636 2 San Jose, California Apr 8, 2011 #8 Scott Greczkowski said: No Playon does not work on the 722 as the 722 does not support DLNA. The 922 however works GREAT with PlayOn and really opens the 922 up with what you can watch. (Now only if PlayOn streamed in HD) Click to expand... T'versity streams in HD and works with the 922 does it not?
Scott Greczkowski Welcome HOME! Staff member HERE TO HELP YOU! Cutting Edge Sep 7, 2003 103,751 29,575 Newington, CT Apr 8, 2011 #9 Haven't tried it but any dlna server will work.
G getstuff4less SatelliteGuys Pro Original poster Jul 24, 2009 235 0 CA Apr 9, 2011 #10 So if my usb adapter supports DNLA will it work?
Scott Greczkowski Welcome HOME! Staff member HERE TO HELP YOU! Cutting Edge Sep 7, 2003 103,751 29,575 Newington, CT Apr 9, 2011 #11 Is a DLNA server? If yes then it should work on the 922.
