I am now leaning towards just replacing my motherboard/processor in my built computer. This will save me money and still allow me to continue to upgrade my PC as time goes on
DDR2 currentlyYou'll also need to replace RAM: modern systems use DDR3 while yours most likely not even DDR.
Also, your case power supply might have to be replaced...
Diogen.
diogen said:I must be missing something: 8 years old PC uses DDR2? And 500W PS?
Diogen.
No.are you buy a barebones kit and adding to it? I don't see a mother board listed, but I do see the listing of USB ports.
I figured a faster SATA drive would be just as quick and I don't need much storage (500 gigs is plenty for me)I didn't want to say anything but I am glad you decided not to go with the ssd's. Just don't hold up over time from what I have been told.![]()
No.
Here are the specs:
Gigabyte GA-880GMA-UD2H Gigabyte GA-880GMA-UD2H Motherboard AMD AM3 880G/SB850 PCI Express 2 DDR3 USB3 ATX Retail from mwave.com
Kingston KVR1333D3N9K2/4G KINGSTON KVR1333D3N9K2/4G ValueRAM 4GB kit (2GB x 2) dual channel 240-pin pc3-10600 DDR3 1333mhz DIMM desktop memory module from mwave.com
Decided to go with 6 core instead of 4: AMD HDT75TFBGRBOX AMD HDT75TFBGRBOX Phenom II X6 1075T 3 GHz Processor - Hexa-core - 3 MB L2 - 6 MB L3 - Socket AM3 PGA-941 - Box from mwave.com
Antec EA-650 ANTEC EA-650 earth watts ATX 12v v2.2 eps 12v v2.91 650w 80 plus / nVidia sli certified ul & fcc active pfc power supply for ATX cases from mwave.com
In Win IW-Z638T.CQ350TBL In Win IW-Z638T.CQ350TBL MicroATX Mini Tower Computer Case with 350W Power Supply, Black/Silver from mwave.com
Decided to not go with a solid state drive: Western Digital WD5001AALS WESTERN DIGITAL WD5001AALS Caviar Black 500GB 7200 RPM 32MB cache SATA 3.0Gb/s 3.5" internal hard drive (Bare Drive) 5 years factory warranty from mwave.com
My buddy no longer works for MS, so now I have to buy my own OS: Microsoft FQC-00765 Microsoft FQC-00765 Windows 7 Professional 64BIT English DSP OEM 1-Pack from mwave.com
And this will supply enough power to the USB ports to quick charge my devices and even charge my iPad: GIGABYTE ON/OFF Charge
Limited time offer
