Is there a device which would allow me to see the resolution (1080p, 1080i, etc.) of signals received from the Dish satellite?
Navy, IIRC, I think some 1080p content IS downloaded from satellite, and stored on the receiver as PPV/VOD.No 1080p from Dish satellites. Only certain VOD delivered over the internet.
First, there is no over the air or regular cable channel that broadcasts in 1080P. Further, the dish receiver only broadcasts at what ever resolution you have it set to, either 480P, 1080I or 720P. You can find some discussions about compression used and how it affects the picture if that is what you mean. Or perhaps you want to know what the actual channel is broadcasting at, and if it is being upconverted?
By the way, even some OTA channels that you get directly from your receiver to your TV are not always full 1080I or 720P. When our local NBC went to HD it didn't seem as sharp as the other networks. I was able to turn my antenna and get a MA NBC station in HD and it was sharper. I found out the local NBC was not at what would be considered full 1080I, but was at 1440X1080 rather than 1920X1080. They have since changed.
I've worked for NBC and I think you were incorrectly informed about the output that was being broadcast. NBC is always 1920 X 1080i but the affiliate has the right to run lower bit rates than the full bandwidth. That way they can carry sub-channels like Telemundo.
Not sure I understand, on what was I misinformed. They were transmitting in less of a bit rate, but still at what is considered HD. (1440X1080)
Some video may be at 1440, but many series are filmed and they would be full 1920, like any movie shown.
My local NBC used to have an incredible picture. Then they added a sub channel. It was very noticeable when they cut the bit rate down.
Then they have a fixed bit rate encoder.
Here is actual resolution of OTA ATSC (best case)- FCC's experts report these color/B&W resolutions for HDTV programming - AVS Forum Archive
They need an encoder like KLCW/KMYL/KTXQ uses stuffing two 720p and one 480i signal into their 19MB bandwidth with pretty good results.
That is really old data (2001 post about a 1990s study). MPEG2 encoders are a lot better than they used to be and displays are a lot better also. They should be able to get much better motion resolution than they could 10-15 years ago with state of the art encoders.
Well I'm not seeing it, if anything it has gotten worse. Been watching since November of 1998.
Limited time offer
