I have a VIP 222k receiver and i am getting duplicate hd channels is there a way to put priority hd then sd so I don't have duplicates?
That does work, and then you can hide the locked. Make sure you hide locked or you will run into screens asking for the code.
Alright. So here is where I can learn something. What exactly is LIL as I do not hear it ever here (boy am I ashamed for asking)? If it is something simple, I will feel twice as bad as I do already! Sad but true, we were actually banned for using "slang" or technical jargon, so the art is lost here.
I go with the channel locks and hiding locked channels. It is easiest since you still see the SD channels of channels without an HD feed. It is a pain and takes probably 30 minutes to setup by going through the guide and locking out the dups, but once it is done you have a nice clean guide.
Thanks to those who suggested using the lock and hide approach. Much better than the manual custom list I built that I had to keep checking when channels were added or moved around.
I do have one question though. I have a 622. The locked channels don't appear on TV1 (which is a HD TV) but they still show up on the guide on TV2 (a SD TV). Do I need to go through the same setup on TV2 or is there an easier way? I assumed once I did it on the first TV both TVs would get the same guide since it is the same receiver.
loubon said:Thanks to those who suggested using the lock and hide approach. Much better than the manual custom list I built that I had to keep checking when channels were added or moved around.
Limited time offer
