Gal 15 ITC change | SatelliteGuys.US
Gal 15 ITC change
brex2001
642
2
USA
What was SPD HD is now FNC HD:(.
Same TP, SR, etc as before:
3780V27800, V 1808, A 1809 Dolby, P 1808, 0x71a, 1713 KB/s...ITC.
Thanks again C.E. for not paying your providers!:mad:
Is it acceptable to post things like this in the open forum? I thought there used to be rule that feeds not listed on lyngsat couldn't be posted in the open forum.
Anyway, my undrestanding is the Fox networks are making some major changes right now and moving to a new format.That's probably the only reason your seeing any of their stuff ITC. Don't expect any of their stuff to remain this way much longer. The new receivers will be DSR-6000 series recievers. So, that means digicipher II encrypted DVB-S2. My understanding is they should be making the switch over really soon.
I thought G15 was on the move to a different location...
You might be thinking of Zombiesat?
Galaxy 15, 133W, G1 isn't moving anywhere I know of.
Stefan2K8, do you have access to WUT? Recommend it be moved then.
Iceberg, if you feel this thread should be moved, then please move it to WUT.
Galaxy 12 is at 133w. Galaxy 15 is Zombiesat, which used to be there, but is now continuously moving east, at about 0.2 degrees per day.
Yeah, my mistake about the satellite name. Overlooked changing names in some stbs, didn't I?
Thanks eurosport84.
Indeed that TP is in fact listed on lyngsat, stefan2k8.
Sheesh.
BTW, even Mike Kohl briefly mentioned that channel change on Sat Talk tonight.
Old C-Band Birdview
Circular Signal on chaparral feedhorn LNBF
