HR24 / H24 CE Release 10/1 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Systems in this CE.
H24-100 • H24-200 • H24-700
HR24-100 • HR24-200 • HR24-500
Window of opportunity to download:
Friday, October 1, 2010 11:00PM - 2:30AM ET
Saturday, October 2, 2010 11:00PM - 2:30AM ET
Customer Candidate
New features
None for the release
Improved/Updated
Under the hood
Notes
Please send logs along with all reports, including MRV issues
This CE may remove your guide cache if you did not download a previous CE. Please allow up to 24 hrs to restore your full 14 day guide.
You will lose your guide cache when reverting from CE to national.
Please do not report sluggish issues or missing search results within the first 12 hours after download.
__________________
"Under-the-hood" and "stability" improvements are expected with every release and are not noted here.
New features
CE:03:01(0x03E8) [HR24 only]
Posters everywhere!
DirecTV Cinema enhancements.
CE:03:05(0x03EB) [HR24 only]
Smart Search now gives Top Matches
Improved/Updated
CE:03:07(0x03E3/0x03F8)
MRV (all but HR24-100)
System Test (all but HR24-100)
Finally got it to download here. MediaShare still busted on HR24-500. What a shame.
Finally decided to send a diagnostic report for media share being broke on the HR24-500. After about 10 seconds, the audio will jump ahead and play out of sync. Then the video will jitter every so often. This first started to happen with the last national release and the CE right before the national release. Media Share works just fine on my H24.
Report # 20101001-3902
What external hard drive do I need for a hr24 receiver and what is the difference between estata and stata?
Esata is External.
As for what to buy ?
There are many opinions about that.
I have always had great luck with the Seagate EHD's, I'm using a 1.5 TB one now and have use a 750 previously.
Like I said, others like thier choice, not ALL will work though.
I have noticed the same when scrolling thru the guide, hopefully the CE tonight will correct this, seems that the HR24 has slowed way down recently.
H21 / H23 CE Release 10/15
HR24 / H24 CE Release 10/15
