DISH Network Software Release Notes 9/30/10 | SatelliteGuys.US
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,734
29,519
Newington, CT
The following Software Release Notes are Provided By DISHsupport.COM
The following are release notes provided to me by DISH Network. As we go forward I hope to give you better explanation of what some of these new features and improvements are. Some things listes are under the hood updates and you may not notice any changes for some of these updates.
It should be noted that for most software updates trickle out and it sometimes takes a few weeks before all receivers are updated. If your receiver has not be updated to the new software below, don't worry, you will get it soon enough.
There is nothing you can do to force your receivers to download the new software. As always patience in a virtue!
ViP211/DP411- Software Version L561 - New Features and updates include, Regional outage/004 signal loss fixes, favorites list color change
ViP211k - Software Version - L492 - New features and updates include, Regional outage/004 signal loss fixes, favorites list color change
DP311 - Software Version - P439 - New features and updates include, 004 Fix, hardcoded IRD (DQT) text #3 update, Western Arc Dish 1000.4 and D500+ LNB support, 1-800 DISH phone # update, Basic (EZr) Remote support, remove signal rework text, updated yellow screen saver text, Misc. fixes
DP322 - Software Version - L484 - New Features and updates include, STBH (Set Top Box Health) Live support, EZr (Basic) Remote support, check switch updates, phone line nag pop-up removal, Western Arc 1000.4 LNB support, favorites list color change, dynamic IRD text support, Misc. updates
ViP622 - Software Version L630 - New Features and Updates include, New VOD UI, SVOD, GoogleTV, Pop-Up Rework Phase I, SRS Volume Leveling, extended boot (fan off on reset, forced boot recovery option via front panel), Basic remote fixes, favorites list color change, screen saver yellow text update, Misc. updates
ViP722 - Software Version - L670 - New Features and updates include, New VOD UI, SVOD, GoogleTV Hardware support, Pop-Up Rework Phase I, SRS Volume Leveling, extended boot (fan off on reset, forced boot recovery option via front panel), Basic remote fixes, favorites list color change, screen saver yellow text update, Misc. Updates
ViP722K - Software Version - L668 - New features and updates include, GoogleTV Device Support, Subscription VOD, new VOD UI changes/fixes, Basic remote fixes, favorites list color change, screen saver yellow text update, Misc. Fixes
Our 722 updated last night, but does this bring the menu changes seen on the 722k to the 722? Just curious because most of the content seems to be for a charge. But I'm anxious to see what all else has changed.
The last couple of days I've been going crazy trying to find out if my TV was dying :eek:. My favorites list color had changed, and I thought one of the projector lenses was going out. The reason for my thoughts was because the color is SOOO ugly-looking that I thought "there is no way that this is a 'feature', obviously something is wrong". The thing is everything else was looking good, and I was just wondering, "well, maybe it's my eyes..." :p
When you reboot, there is a new Acquiring Signal dialog with five segments that are traversed by a green bar (similar to program guide download), instead of the "2 of 5" style text. It is accompanied by "This should take no more than 5 minutes", but took less than a minute.
Assumed it was the same as the 622, but who knows... Interesting note with the Google TV piece... Are they turning the device into a Google TV, OR just putting in the firmware to support Google TV... Hmmm...
Just support for the GoogleTV hardware so that it will accept commands and send data back.
Same here and it was the first thing I looked for when I saw there was a software update.
SRS is supposed to be on Audio screen where you select things like Bitstream/PCM and Stereo/Dolby Digital.
When did the Sony Movie channel start with a sd feed?
Uplink Reports?
