I'd like to pick up the Fox (channel 18/virt channel 43) and CBS affiliates from Myrtle Beach to get just slightly out of market NFL games from my home near Mount Pleasant, SC. It's just under 100 miles to the antennas, flat ground, and I'm just past the purple at TV Fool. That said, I'd be clearly DXing in the afternoons (1-7pm), which I understand might make things tough. If tropo is a daytime occurrence, it looks like I might have good and bad Sundays.
I've read up on the antenna options and a bit about amplifiers. It looks like an Antennas Direct 91XG is the right (or at least a good, affordable) choice, but it needs to be up pretty high, I think -- say 20-30 feet. I've also got a fair number of trees, but I'm not sure if that's as big a deal (oops: the HDTV Primer says, "§ UHF -- It is best to assume that trees block all signals."). I've got an indoors DB2 right now which, natch, gets nothing from Myrtle Beach.
From tvfool.com for Fox
(if I get this channel, imo, I "win")
Fox -- WFXB
Real: 18
Virt: 43-1
NM (dB): -18
Pwr (dBm): -108.8
Path: Tropo
Dist Miles: 96.4
I might be willing to put an antenna on a mast on my single story garage, but past that I'd like to get an expert. I've called dish installers and TV repair places, and nobody will or knows of someone that'll install an OTA antenna. It was pulling teeth to get my electrician to run coax to my roof when I built the house, strangely enough, and he (nice enough guy) said he didn't know how to install an antenna. :shocked
Anyhow, any ideas or advice? Far and away the best post I've found is this one and the description of "fringe" on the HDTV Primer is excellent, but as far as finding an installer that can figure out my specific issues (specific channels, etc) better than my guessing, I'm lost.
I realize I might not be able to pull it off.
Fun trying though, right?
Fox -- WFXB
Real: 18
Virt: 43-1
NM (dB): -18
Pwr (dBm): -108.8
Path: Tropo
Dist Miles: 96.4
