Because the skew for AMC1 in Ku is so odd I decided to put up a dish just for the S2 feeds there. I had an old DirectPC dish, scalar & Hughes lnb on hand I thought would work well for this.
I took a 11" length of 2" pipe, cut 2 1/2" x 3" slots 180 degrees apart, drilled & tapped two 3/8-16 holes in between the slots for the 3" vent pipe mount. Although the pipe isn't exactly plumb, it's close enough for a fixed dish.
After experimenting with skew angles using an adjustable scalar split ring & Starband scalar I confirmed the skew angle needed was about 45 degrees for best Q. The scalar that came with the dish didn't have holes in the C120 flange at 45 degrees skew, so I drilled four holes for this. The Starband scalar was picking up noise outside the dish face causing the signal Q bar to 'bounce' on some TPs. The lnb skew angle for my long & lat(118W x 34 N) is -46.9 degrees.
I added a 4x1 diseqc switch after the Ku & C-band multiswitches to tie in the Ferguson Ariva 100 to the WSI 36" motorized dish, the 7.5ft Perfect 10 C-band dish & the DirectPC dish. I'm glad I finally changed this. There's a lot more HD fta up there to be had nowadays.
