Went to work on a H-H motor tonight. Need 85w for my true south sat, was there a few weeks ago, nothing now. Equipment? Weather? Me?
12184 H 3978 AMC 16 test card.
Jim
Jim
Seems like they have turned off the color bars at the moment, lol. they only do that when somebody needs to aim a dish! Stand by, I will scan it for you and see if anythings there......
Tantalus: try these 3, HS football games on 85w right now
12191H 6111 SD
11987H 13235 SD
11969 H 13235 HD
720pm C
Come on down, the weather is definitely warmer. Maybe your dish is the problem-how big, what lnb are you using? I get that satellite largely, either on my 1m or my 90cm dishes, both are channel masters with aftermarket lnbfs. If you're motorized, maybe you haven't got the dish tracking just so-so yet.
that test card is up sporatically
Sometimes its better to use USALS and move the dish to 83 or 87 first and then aim at that
If you want to go that route in your receiver set up USALS. Put in your latitude/longitude. Then select 87W or 83W. The motor will move a little bit (since its only 2 degrees away) then you aim the whole motor/dish assembly at 83 or 87 (whichever you picked) to lock in signal
Basically what you would normally do for your true south but because its 2 degrees off you need to motor to move first
I had to do that with my 2nd motorized. At the time there was nothing on 93W (my true south) so I used USALS to have the dish/motor move to 95W then aimed the whole assembly at 95 and locked it in
During most of the weekdays, between 5:00 - 6:00 (EST)
Globaltor Feed..12193 - H - 5.858
Limited time offer
