TV Remote Code for Vizio SV370XVT | SatelliteGuys.US
SantaCruzJoe
7
Santa Cruz, ca
I have dish network with a VIP722 receiver / DVR. It is connected to a Vizio SV370XVT. The manual for the receiver has codes for LOTS of TVs but doesn't have TV codes for any Vizio TVs. I did a code search and found one that will turn my TV on and adjust the volume but the input button does not change inputs on the TV.
Does anyone know the code for this TV?
This has become urgent because someone in my house misplace the TV remote so I'd like to be able to change inputs using the Dish remote.
Figured out I'm using 515 for my Vizio 32". Doesn't change inputs but one thing I really like is the "format" button runs the sleep timer. Even the original Vizio remote doesn't control the sleep timer without going into the menu. Actually use that more than the input button so I guess I'll stick with 515.
My Bad! Did not know you lost yours, but I do believe that the 21.0 has a lot more codes built into it then the other Dish remotes.
Dan
MTV HD video problems
Is going from a 722 to a 612 an Upgrade?
