I can get all transponders on C band. However this sat requires circular polarization (R & L).The strongest transponder is 4071R that will peak your meter, or still be viewed with a linear lnb at lower levels.
As far as Ku 12005v but is scrambled, but it is the only consistant signal unlike the rest which is feeds only for the Americas.
I use the 6 ft Fortec Star dish controlled with a 24in actuator running on a GBOX3000 to position the dish. I use a DMX741U with the teflon insert for circular reception (C/Ku) with an AZBOX Premium Plus.
