Is the HDMI from the Sathawk connected to a Receiver or TV?But I Still Cannot Get ac3 To Work Thru Hdmi.
If you change the extension of the database file that the receiver saves from ".dbs" to ".abs" you can then edit that file with the editor. When you are finished editing, you save it to the ".abs" as a "user database" and then rename the extension to ".dbs". The receiver will then be able to load your edited file.You can't use the editor program, posted elsewhere, on the channel list file though. The editor only works on a copy of the full firmware image (which you can also dump now). That seems stupid.
Also, to those wondering how to change the background image, it's quite easy to do:
1. Make your own .jpg image of 720X576 pixels using whatever picture editing program you have.
2. Find a program such as BatchDVDStreamsConverter or FFMPEG.
3. Convert the file to a .m2v file and load into the receiver.
Hi All, I hope you like the progress on this receiver. Let us know if any other changes required.
Are you going to get any of the new style remotes in for these?
will you be selling the remotes separately?![]()
heres some interesting news by the Company that i think makes the sathawk,solomend and others. wondor why they did this? DVB|LNB|Dish|Dreambox 500s|Strong 4663x|Captiveworks 800s|wireless share smart card|Shenzhen Wanying Electronics & Technology Co.,Ltd
Limited time offer
