Fortec mercury II | SatelliteGuys.US
Fortec mercury II
sweatherbie
5
Lancaster, Pa
When following the instructions for the G19 set up with 1 LNB, how many channels will I receive? On the video it shows 14 when I do it I get 13. How would you go about programming the rest in in an easy way?
  • You may manually scan all transponders frequencies listed on the Glorystar Channel List.
or
  • If you want all of the FTA channels on G19, press the P.SCAN button on the remote, change the Scan Mode to SCAN FTA, select START SCAN then press the OK button on the remote. All free channels on the satellite will be scanned into your receiver.
What player can you play a .TS file ?
Glorystar Welcomes New Channel - PromiseLand TV
