Pansat 9200 HD or Viewsat MAXHD? | SatelliteGuys.US
I'd go for the 9200 and get the DVB-S2 module to go with it.
What does this module do? Also, I assume it has blind scan and supports USALS well...
It will allow you to see DVB-S2 channels in SD/HD 4:2:0 and yes you will be able to do Blind scan with DVB-S2 as well.
Without the module you will have DVB-S SD/HD 4:2:0 with blind scan also.
And no, you will not be able to see 4:2:2 SD/HD with or without the module.
Are there channels out there on KU in 4:2:2?
Now computer you have a choice of PCI, PCI-E and or USB tuners.
Azbox? Does the Premium blind scan? I've seen contradictory info on this...
Speaking of Viewsat, I just looked at their web page:
UNDER CONSTRUCTION
It's gone, replaced with a hosting company's "Under Construction" page. Final nail in their coffin?
Fortunately my MAXHD still works fine even though it won't do DVB-S2.
So, Iceberg, is Azbox a favorite for HD? Can you confirm that blindscan works?
Satellite Finder Software!
Cotto vs Foreman 6/5/10
