922 streaming in HD issue | SatelliteGuys.US
bradfordj
204
5
CA
Has anyone had problems with the slingplayer when set to HD at dish.sling.com? The video is sluggish and the audio goes in/out. It's streaming at about 4,000 Kbps.
When set to SD it seems fine. It looks much better in HD though. They gotta get the streaming side working more smoothly. That's the whole point of this receiver - to be able to watch live TV/DVR shows "anywhere". Even on the iphone 3g the stream is sluggish. I'm using a Linksys WRT400N rougter and using a homeplug adapter. Is anyone having any luck watching the slingplayer at dish.sling.com in HD smoothly?
Thanks.
I do not have much issue with it using wired eithernet. It looks like it goes up to 7 mbit/sec, but it usually stays under 5. The main issue I have is how to control it. I have to escape full screen to work the virtual remote that is very sluggish, then go back to full screen for commercials. Occasionally the audio is a bit out of sync. It is like it slows the bitrate way down, they it slowly speeds back up.
I find the whole thing very annoying. I much rather be able to use the sling software in HD to connect to the 922.
Thanks.
It will not play HD on my PC smoothly at all. I'm having basically all the issues you are having.
Ok. I just wanna make sure it's not me before I shell out on routers, adapters and faster internet for this thing. They gotta get this HD video streaming thing running smoother. I tried streaming with my iphone in the car on standard and the video stream was grainy and at times sluggish. Even changing channels and accessing the menu/guide is slow. They should have the guide a touch screen kinda like the dish remote access.
They have their work cut out for them. If Youtube and Hulu can do it, Dish and Sling Media can do it. Unfortunately, I think it's never gonna be perfect.
Dish VIP 722 Receiver Won't Turn On
Using a 300 Dish with a 211k receiver
