east of 72w question | Page 2 | SatelliteGuys.US
press tv-12172h27500 1301/1311/1301
I could swear I had Al Jazeera English recently.
Hey, keeping with the theme of this thread. Is there any linear Ku between 30w and 63w reachable from Minnesota?
53W (need Universal LNB)
H-11633 03.111 CRISTIANA-CANAL 27 Guatemala City, Guatemala
43W
V-11956 03.125 TELEVISA CHIHUAHUA Ciudad Juarez, Mexico
V-11995 02.865 TV PUEBLA Puebla, Mexico
V-12003 03.125 TELEVISA NORESTE Mexico
I dont know about 43W. I got it from global-cm.net
I need to scan 43W one of these days to get a update to thelist
also, to anyone who is currently pointed at hispasat 1c/1d, how strong is this sat? how big does a dish on this sat need to be to be reasonably reliable?
thanks,
Denny
I have successfully used Dish500 to get a 55-65 Quality on a single setup.Hispasat is a pretty strong bird.Withbigger dish U can do a lot better.
can we convert the freq to what it would be on a standard LNB?
not for 53W...frequency is below 11700
here is an idea for an experiment, i have a few directv b-band converters, they basically are a 22khz controlled add on local oscillator that boosts the input frequency by 1400 mhz.
with a dss lnb with a lo of 11250 converted to linear by removing the dielectric plate it would give an if of 383 mhz on this transponder
with a b-band converter boosting the frequency by 1400 mhz, it would give an if of 1783 mhz, well within the L-band range.
theoretically this should work, barring any unforeseen problems, such as a bandpass filter in the dss lnb blocking lower frequencies.
think i'll try it this weekend:)
btw, has anyone else tried using b-band converters with fta??????
sure, anytime:)
keep in mind that this is with about 275 feet of rg6 copper clad steel wire, 2 diplexers, and a 22khz switch in line with a super dish with the fss stacked lnb
with the lo set at 13850.
pansat 2700a
i am sure that i am loosing a lot of sig q and quite possibly not getting some transponders that i would if i had a shorter wire run, a bigger dish, or didnt have the diplexers or switch in line.
plus the frequencies will be off and all of them come through as horizontal because of the stacked lnb.
but anyway, here they are,
14984 27.500 cubavision, tele rebelde, educativo, educativo 2, cubavision internaci, acn, contribucion
15037 7.500 telecaribe columbia, zoom, rci
15151 27.500 rtpa internacional, tvga, tv3 cat, etb
15524 27.500 no tv ch.
15568 27.500 no tv ch.
15725 27.500 no tv ch.
15246 4.200 no tv ch.
15269 5.240 (really low sq) solo tango, supreme master tv
15525 27.500 press tv, kuwait tv, tv marti, c canarias tv, ktv ch2, youth sport, al minber tv
15566 27.500 syrian tv, abu dabi tv, oman tv, al iraqiya, saudi tv, qatar tv, sharjah tv, sudan tv, jamahirya tv, syrian drama channel, saudi sunnah
Hispasat 1C at 30.0°W - LyngSat lyngsat page on this bird
hope this helps,
Denny
Great info!!!:up
BSC621??
Breakup in Ku band
