Iceberg, here is another hd unit, but only mpeg2, read line 20
Mr. Crane,
An HD receiver that doesn't do MPEG4 will not get you alot of the FTA HD out there. I have about 2 of them. A good example is the Captain 8000HD.
Connect the external hard drive to your computer and see if the recorded file is on the hard drive. If the file is on the drive, then recheck where you are looking for it in the receiver's menu. The owner's manual gives a pretty good description of locating a recorded file.
It is a good idea to back the receiver's data up so it can be reloaded when needed.
Mr. Crane,
Thanks for the reply, Greg.
I've noticed the manual on Sadoun's site shows a lot of menu items that no longer exist or were changed in version 325.
Does anyone know if an updated manual (in English) is out there anywhere?
Also, can you point me towards info on backing up my settings?
http://rapidshare.com/files/374637125/Solomend800_Loader_Editor.rar
Then 402 file has some new things added that are not in the 325 file.
In the instruction manual that is found on Sadoun's website, Pages 27 and 28 have the recorded file information. Look in the Record Manager menu for your recorded file.
You can download the channel editor program in the link.
Code:http://rapidshare.com/files/374637125/Solomend800_Loader_Editor.rar
http://rapidshare.com/files/381757824/HDS2_CMT_1004020527.abs
Guys,
For those who want to use the C/Ku lnb on a single motorized dish with this receiver, I have a work around that should work with a 22k switch and a motor.
1. First, connect both terminals from the lnbs to the 22k switch. ( I'll advice you not to use a Universal ku lnb.)
2. From 22khz switch connect to motor or to Gbox.
3. Setup Antenna as " Motor Antenna" on Receiver
4. Configure the lnb as Universal lnb but change the values from 9750/10600 to 5150/10600 ( if ku lnb is universal) or to 5150/10750 ( if ku lnb is standard)
5. Now Blindscan
Let me know if you have any questions
Smart. Great idea. Too bad I have 3 lbs on my Big dish... I will just go without ku circular for a while.
i think you need to set it up on the pc to send it then after you click send on the pc instantly flip the back power switch.
Did you do this?
Turn the receiver OFF by using the rocker switch on the back, Start the loader program with the file you want to load, Turn the receiver ON using the rocker switch after the loader program has started.
Limited time offer
