Of course, JTAG is useless unless you have a complete dump of another box with similar peripherals. Im assuming the Solomend isnt a trailblazer and essentially copied a reference design from Ali or another box maker.
So it will not decode AC3 audio even through the HDMI cable?ac3 audio
stutter free video
First thanks!Terry, there are lots of things that this box will not do such as scan a skinny transponder(sr around 2000 or less). To me, most of what this box will not do are only nuisances because I can work around most of its problems. A satellite system that has a single lnb and a motorized dish should not have many problems with this box.
Let us look at your list of problems.
(1) "Move a dish, and work the switch at the same time."
True, you cannot actually use different switch settings and the motor at the same time, but you can use one diseqc switch setting for a motor and use the other diseqc switch positions for fixed dishes if you toggle back and forth between Fixed Antenna and Motor Antenna in the Antenna Connection menu.
The receiver will default to the last diseqc switch position you were using when you change from Fixed Antenna to Motor Antenna. As an example, I have my motorized ku lnb on diseqc port 2 and I have c band lnbs on diseqc ports 3 and 4. If I want to watch C band, I have to change to fixed antenna which allows the diseqc switch to work. If I want to use motorized ku, then I first need to select a ku satellite that is set to diseqc port 2 and then change to Motor Antenna in the Antenna Connection menu. This will allow my motor to move and I can view any satellite that is available with the diseqc port 2 lnb. If I change from Fixed Antenna to Motor Antenna while I am on a satellite that uses diseqc port 3, then ther motor will work but the switch will be stuck on port 3. So you can use this box with a switch and motor but it is aggravating. (There are other ways of using a switch and a motor but this one works the best for me.)
(2) Manual PID entry.
The receiver does not have provisions for this but there is a channel editor program available that works very well with this box. Manual channel entry plus other satellite information changes or additions are very easy to do with the editor. A computer serial port and a null RS232 cable are suggested to use the editor unless you want to modify and reload the firmware.
(3) 4.2.2.
This receiver cannot view 4:2:2
I am now thinking fixing the motor/switch issue on this receiver is just a matter of changing the menus of the main software only.
Reason, i say so is because using a universal lnb with motor on this receiver works pretty well. All Universal Lnbs have a 22khz switch in them and by selecting the lnb type as universal, the receiver automatically switches the 22khz switch between both LO frequencies.
So am confident, this receiver can control both motor and switch at thesame time because it is working well with my universal lnb and motor.
So my conclusion is that it is just a little tweak in menu that will fix the issue. Now why has this not been possible by the manufacturer given the interest in this receiver?
Iceberg, here is another hd unit, but only mpeg2, read line 20very true. Why cant they get it to work with a 22k and a motor?
The issue right now is the motor settings you can only have one LNB setting (well two with a Universal)....
First thanks!
Ok now if I where to hook one of these up slaved to my 4Dtv, using the 4D as a mover I should not have any problems with the switch correct?
I think I could handle a channel editing program so no problem there.
So this box will do S2, and 8psk?
Thanks again
Terry
It does S2. I have not tried any 8psk channels, so I do not know about them. GregH
For some reason when I try to record with my SatHawk, it shows that it's recording, but when I check the recording manager, it doesn't show up.
I've successfully recorded to my external HD before, so I'm a bit perplexed.
Any ideas?
I'm hoping to avoid resetting the unit and losing my data.
But when they say 22k does that mean just a UNiversal LNB?
All the other HD receivers I've worked with could work with a motor and a 22k for sure. Some worked with motor and Diseqc 1.1 if you wanted too![]()
Limited time offer
