722K software L661 | Page 2 | SatelliteGuys.US
722K software L661
Mostly good
So far most everything in this update is good. The volume leveling stinks though for those that wanted it you will have it. It is 1 of the worse sounding comp/limiters I've ever heard. It pumps like a bicycle pump: in-out in-out. Had to disable it really quickly before it made me puke.
Hmmm, I've been using it since the update and watched quite of bit of Dolby Digital and non-Dobly Digital and haven't noticed this.
It seems like the volume leveling feature actually works. (Thanks Dish--and it's about time!)
The VOD advertisement in the guide is lame. Thankfully it can be turned off. Also, I don't think it appears if you are using a favorite list that excludes the 501 VOD channels.
How do you turn off the advertisements?
Only the "Shadow" knows. Wait a minute he says could be a while. :D I'm not the only one that doesn't like it. My brother called to ask what was wrong w/the sound now. I had to talk him thru how to disable it.
Has anyone noticed on the Dishpass that when you go to set a channel number it gives you an "invalid". This happens when editing and existing or creating a new dishpass. It was fine on the last software.
Are they pushing it out one box at a time? They started pushing it out over a week ago and you would think they'd be done by know. My wife bitches every time a commercial comes on that is twice as load as the regular commercials or shows.
250k
Are they pushing it out one box at a time? They started pushing it out over a week ago and you would think they'd be done by know. My bitches every time a commercial comes on that is twice as load as the regular commercials or shows.
They started out w/ 250k the 1st wk. So maybe that many per wk.
Commsocpe cable identification
DISH to offer Locals in all 210 DMA's
