BIO HD why Dont we get it? | SatelliteGuys.US
LOBO2999
823
Cumming, GA
Its not part of the HD EXTRA PACK BIO HD that is and I dont get it one any of my D HD Recivers , I have reset them but nothing . Are we suppose to get it ?
Thanks!
Thanks!
Currently, Bio HD is not part of the HD Extra Pack, and I do not think that will change. Currently, Bio HD is part of Choice Xtra package with HD Access; Bio SD is in Choice Xtra. If you have a package above Choice Xtra like Choice Ultimate for example, then you should have it.
I have total choice Plus
That is odd since Biography Channel was part of Total Choice Plus when it was an offered package. Therefore, I would think you should get it, but you never really know with grandfathered packages I suppose. Do you get Biography Channel SD? You may need to call in to let them know or ask, and that may fix the problem.
Yes I do get the SD version of it. Will hve to give them a call Friday morning and see.
Thanks for all the replays
HD DVR use
HD DVR
