Needless to say I'm not happy, it may not be the nicest house in town but when a tech is there from 4pm till 10pm and he has help you expect the job to be done right. With what this guy did it would have taken an hour tops.:rant:
He ran all new, the barreled line is a cox line that will be replaced in the future when I re-wire the house to bring all the lines internal. The ground wire you see is from the direct installation which was also another headache install.That's craptastic. Unfortunately I have seen worse. You would think the tech would have rewired the whole house if he took that long. I notice that he barrelled new to existing lines and what is with the ground block? It looks like there is a green ground wire laying on the ground not attached to anything.
Sorry about the quality of the work. I can assure you that most installers do much better work.
Did you not look at what the installer done before signing off on the order?
Unfortunately, I see this level of work quality all the time. Your install would definitely fail a QAS on many aspects. What a hack job! I look back now at the quality of my work today in comparison to the first few jobs I did on my own when I became an installer and I have to say, never on my worst day did anything I ever did compare to this! And now some other poor guy is gonna have to fix all that.
It would still fail on the ground issue because there is a ground available. Only if there is truly no feasible way to ground does the grandfather clause save you.wow. i always try to cut corners while installing but usually wuss out. ive never seen it run under the shingles just to save some screw clips. Was this a new install or did you move to this house with service? Cuz if you already had service and moved it is actually okay with the NEC to not ground it cuz your grandfathered in, but i have a feeling that this was a new install!!
Limited time offer
