List of Spotbeams going active on EchoStar14 (including maps!) | SatelliteGuys.US
digiblur
14,190
4
Louisiana
Here it is everyone! I have all the beams matched up to the transponder IDs. This should give you an idea of what will be available in your area.
This is the list of current new transponders for E14 in the system right now, this is NOT all the capabilities of this satellite. Each spotbeam should link to the map it covers.
Transponder Changes:
EchoStar14 119W TP 05 Spotbeam A1 20000 QPSK 7/8 added
EchoStar14 119W TP 02 Spotbeam A2 21500 8PSK 2/3 added
EchoStar14 119W TP 04 Spotbeam A2 21500 8PSK 2/3 added
EchoStar14 119W TP 02 Spotbeam A3 21500 8PSK 2/3 added
EchoStar14 119W TP 04 Spotbeam A3 20000 QPSK 5/6 added
EchoStar14 119W TP 05 Spotbeam A4 20000 QPSK 7/8 added
EchoStar14 119W TP 04 Spotbeam A5 20000 QPSK 7/8 added
EchoStar14 119W TP 01 Spotbeam A7 21500 8PSK 2/3 added
EchoStar14 119W TP 05 Spotbeam A7 21500 8PSK 2/3 added
EchoStar14 119W TP 02 Spotbeam A8 21500 8PSK 2/3 added
EchoStar14 119W TP 02 Spotbeam A10 21500 8PSK 2/3 added
EchoStar14 119W TP 01 Spotbeam A11 20000 QPSK 7/8 added
EchoStar14 119W TP 05 Spotbeam A11 20000 QPSK 5/6 added
EchoStar14 119W TP 02 Spotbeam A12 21500 8PSK 2/3 added
EchoStar14 119W TP 01 Spotbeam A13 21500 8PSK 2/3 added
EchoStar14 119W TP 02 Spotbeam A14 20000 QPSK 7/8 added
EchoStar14 119W TP 01 Spotbeam A15 21500 8PSK 2/3 added
EchoStar14 119W TP 02 Spotbeam A16 21500 8PSK 2/3 added
EchoStar14 119W TP 01 Spotbeam A17 20000 QPSK 7/8 added
EchoStar14 119W TP 03 Spotbeam A17 21500 8PSK 2/3 added
EchoStar14 119W TP 02 Spotbeam A18 20000 QPSK 7/8 added
EchoStar14 119W TP 01 Spotbeam A20 21500 8PSK 2/3 added
EchoStar14 119W TP 05 Spotbeam A20 21500 8PSK 2/3 added
EchoStar14 119W TP 05 Spotbeam A22 21500 8PSK 2/3 added
EchoStar14 119W TP 01 Spotbeam A23 21500 8PSK 2/3 added
EchoStar14 119W TP 01 Spotbeam A24 20000 QPSK 7/8 added
EchoStar14 119W TP 03 Spotbeam A24 20000 QPSK 5/6 added
EchoStar14 119W TP 05 Spotbeam A24 20000 QPSK 5/6 added
EchoStar14 119W TP 02 Spotbeam A25 21500 8PSK 2/3 added
EchoStar14 119W TP 04 Spotbeam A25 20000 QPSK 5/6 added
EchoStar14 119W TP 01 Spotbeam A26 21500 8PSK 2/3 added
EchoStar14 119W TP 05 Spotbeam A26 21500 8PSK 2/3 added
EchoStar14 119W TP 03 Spotbeam A27 20000 QPSK 7/8 added
EchoStar14 119W TP 05 Spotbeam A27 20000 QPSK 5/6 added
EchoStar14 119W TP 01 Spotbeam A27 21500 8PSK 2/3 added
EchoStar14 119W TP 02 Spotbeam A28 21500 8PSK 2/3 added
EchoStar14 119W TP 04 Spotbeam A28 20000 QPSK 5/6 added
EchoStar14 119W TP 01 Spotbeam B2 20000 QPSK 7/8 added
EchoStar14 119W TP 03 Spotbeam B2 20000 QPSK 7/8 added
EchoStar14 119W TP 01 Spotbeam B3 20000 QPSK 7/8 added
EchoStar14 119W TP 03 Spotbeam B3 20000 QPSK 7/8 added
EchoStar14 119W TP 03 Spotbeam B7 21500 8PSK 2/3 added
EchoStar14 119W TP 02 Spotbeam B8 21500 8PSK 2/3 added
EchoStar14 119W TP 04 Spotbeam B9 21500 8PSK 2/3 added
EchoStar14 119W TP 03 Spotbeam B10 21500 8PSK 2/3 added
EchoStar14 119W TP 05 Spotbeam B10 20000 QPSK 7/8 added
EchoStar14 119W TP 04 Spotbeam B11 20000 QPSK 7/8 added
EchoStar14 119W TP 04 Spotbeam B12 20000 QPSK 7/8 added
EchoStar14 119W TP 03 Spotbeam B13 20000 QPSK 7/8 added
EchoStar14 119W TP 04 Spotbeam B14 21500 8PSK 2/3 added
EchoStar14 119W TP 05 Spotbeam B15 21500 8PSK 2/3 added
EchoStar14 119W TP 03 Spotbeam B16 20000 QPSK 7/8 added
EchoStar14 119W TP 05 Spotbeam B16 20000 QPSK 7/8 added
EchoStar14 119W TP 04 Spotbeam B17 20000 QPSK 7/8 added
EchoStar14 119W TP 04 Spotbeam B18 20000 QPSK 7/8 added
EchoStar14 119W TP 02 Spotbeam B20 21500 8PSK 2/3 added
EchoStar14 119W TP 04 Spotbeam B20 20000 QPSK 7/8 added
EchoStar14 119W TP 03 Spotbeam B21 20000 QPSK 7/8 added
EchoStar14 119W TP 01 Spotbeam B22 21500 8PSK 2/3 added
EchoStar14 119W TP 03 Spotbeam B22 21500 8PSK 2/3 added
EchoStar14 119W TP 05 Spotbeam B22 21500 8PSK 2/3 added
EchoStar14 119W TP 04 Spotbeam B23 21500 8PSK 2/3 added
I've noticed some areas, such as the south east, have 8PSK spotbeams as well as QPSK spotbeams. Will the 8PSK ones be used to add missing HD cities, or fill in the missing channels in existing cities (such as HD CW MyNetworkTV)?
Thanks Digiblur!:up
The ones For Puerto Rico looks nice!
Glad to see the one beam that covers my area, A12 is on. Sadly, it can only broadcast of TPs 2 and 8. We know from the FCC application, they have no immediate plans to use any TPs higher than 5 for spots.
For being a massive spot, covering Indiana and Ohio, I wonder what the plans are. Besides putting one of our RSNs or 2 on there, I bet my DMA sees nothing.
I'm guessing the QPSK ones will replace the existing E7 beams and SD locals, while the 8PSK will be more for HD LiL and maybe some RSNs?
By the way, thanks for the hard work!
*First of all... Thank you very much for posting this, Digi. You give us some of the best info on the site*
Seeing the footprint of A13, makes me wonder why my locals are going to be on 77.
They will have lots of dishes to change out. Maybe they will change their mind and put them on A13/119.
Yes, you can say the 8PSK ones will be HD for the most part. Although there are a few SD DMAs that have gone on 8PSK beams on Western Arc. Alexandria, LA is one that I know of offhand. So it isn't a guarantee.
You never know...they might be in a holding pattern. But the only thing with A13 is it transmits on 1, 7, 9, 13. And as of now they are only using 1-5 to transmit on as 6-21 will be used for CONUS. The might not want to back themselves into a corner by putting two markets of HD locals on one transponder.
Another example of this is.... on 129 they had a beam covering the Lake Charles, LA DMA with only 3 HD channels on it(Lafayette, LA locals). Lake Charles only has NBC, FOX, and PBS in their market and it would have fit perfect on that transponder with Lafayette, LA. But nope, they added Lake Charles on 77w. So definitely some future planning going on that you and I might not see.
And I don't know if I beat Scott G on offering the best info ;)
Additional tid bits I have confirmed from other contacts on E14...
Their plan is to launch 4-6 HD channels per DMA. The current SD DMAs will remain on spotbeams in MPEG2 mode for now. They have 5 new HD markets and 14 new SD markets planned. I believe some of these were talked about on the Charlie Chat & Retailer Chat.
CONUS TP 2 content will move to TP 7. CONUS TP 4 will move to 9. And of course spot beam 7 and 9 will go away and 2 and 4 will become spotbeams. Even swap.
Guys i dont understand how would these work for Kentucky. We are on eartern arch satellites. would they switch everyone around?
If you are already on EA with your HD locals then you're good to go, don't worry about this satellite as it probably will have nothing to do with your DMA.
I'm threw together the list of current TIDs that are slated to be active, kicked out the ones that transmit on TP 6 or higher, kicked out the shared uplink ones, and there's 3 more TIDs they could light up.
As soon as I can I'll get the list together in a readable format to show you guys what they will be using and what will be idle for now.
ViP 612 will not take a software download
charge 5.00 for no land line
