FTA in Curacao, Netherlands Antilles | SatelliteGuys.US
Mateosat
24
Caribbean
Hello to all,
I am fairly new to the world of FTA. I live on a tiny island in the Caribbean called Curacao. It is located just off the northern coast of Venezuela and it's the sister island of Aruba.
I was wondering if any of you are located in my region and which birds are available to you. So far I managed Satmex 6, Galaxy 19, AMC 21. I want to receive AMC 4 but I figure need a bigger dish. I've got a 50cm for Satmex 6 and a 78 cm for Galaxy 19.
I'm looking forward to replies from hobbyists in my region.
Mateo
HI
I'm located in Puerto Rico which is close to Curacao. I have Galaxy 25, AMC 2/4, Telestar 5(Galaxy 19), AMC 21, Intelsat 14 amd NSS 806 I know that there are some more availables in our area. Regards
I see you have AMC 21, I have a question for you, are you able to have audio on TP12180
Create, V-Me and PBS World TV?? I can watch them but I have no audio
Regards
Regards
You need an AC3 Audio capable receiver to play the audio. BTW, what receiver do you have?
Hello to all,
Mateo
Welcome to SatGuys!! :welcome
I'm not from your area, but you need a dish of 90CM (36 inches) or bigger to really enjoy this hobby.
AMC 21 125 W Audio Problems
Hi there
Just wondering if anyone have come up with a solution to solve the problem with the audio on TP 12180 (Create, V-me and Pbs World) on AMC 21 125 west Ku area. I can watch them perfectly but with no audio at all. It is classified DOLBY AC-3 in my STB,
any help will be highly appreciated!! Thanks
Carlospr43,
The audio on those channels - save for Montana- is in AC3 format. You need an external decoder. Some receivers have an internal decoder. Most don't however.
Thanks a lot Mateosat, do you know of any external decoder brand/model that I can look at?? Again thanks a lot
What receiver?
My Azbox decodes AC3 and outputs on the L/R channels
With most DVB you will get that signal from the optical output and need and external decoder to get sound.
Carlospr43,
I'm looking on the web for a solution to get audio on those AC3 channels. I would like to decode the audio with my pc soundcard. I don't know if it's possible. My receiver does have a spdif output, but my soundcard is just your plane-jane 1/8 phono jack input (line in and mic). I guess it's not accepting any digital input. However, I hear that some cards can do the job (SB Extigy for example).
thanks, I just found out that you can buy a digital cable for the S/PDIF connector directly to your 5.1 or so Home Theather. I'll get one tommorrow and will keep you posted!! Thks
The Cyberhome Sonic Voom is one of the most widely used external AC-3 (Dolby Digital) decoder solutions used here, and probably the cheapest too. The unit is designed for surround headphones, but you can connect the headphone outputs to line level inputs on a stereo, TV, etc. as well.
To get AC3 audio on 125 you need :-
New Sonic Voom surround sound headphone MP3 MP4 ZUNE on ebay
I am in Panama Central America not too far from you I am getting on a 6 foot offset ku dish :-
125 w,,97 w, 58 w
I am looking for other birds as well but this is what I get so far
On a 24foot C band BUD I can pick up :-
121, 116, 113, 103,101,97.
I am only looking at the western segment so far. In time I will explore the eastern sgment.
Hope this helps
Tony
Not necessarily true.
125 w,,97 w, 58 w
Hope this helps
Tony
QUOTE=tonydix;2150135]To get AC3 audio on 125 you need :-
New Sonic Voom surround sound headphone MP3 MP4 ZUNE on ebay.
My 5.1 decodes the AC3 audio with regular rca cable connectors, I don't have any headphone connected to it.
rca cables from azbox to 5.1
Hola Carlos.
If you have a 5.1 tuner it will decode the audio for you, the tuner must be in surround sound option, granted you must have a SAB that will receive AC3 audio ( aka azbox elite or alike ).
Good luck.
Granadaguy.
Hello to all,
Mateo
Welcome to the forum buddy! amc 4 101 is going to change pretty soon so you will probably loose that sat.
Prof 7300/7301 and motor control
TITAN TV has died
