ok, money is kinda tight right now, so most anything i use for this hobby i need to either recycle or build myself.
i was just pointed at 101w ku before this.
first i started to put multiple super dish lnbs on a superdish,
but then i got to thinking that with parts i have saved, i could possibly build a dish mover and make a 1m primestar dish movable.
so i dug through my parts and built one.
i started with 2 direcway mounts and mounted them back to back
the one on the pole in the ground has the skew plate set at 0 so it is perpendicular to the ground
the skew plate on the one with the one with the 45deg mount pole is left loose so it is capable of rotating
i then set the mount on the pole in the ground at 45 deg el and set the skew on the rotating skew plate at 0 and put a level on top of the mount and adjusted the elevation on the 45 deg mount pole to level the top of this mount so the 45 deg mount pole is at exactly 45 deg
i then mounted the primestar mount upside down on the dish and mounted it on the pole.
i then moved the elevation on the mount on the pole in the ground to 48 deg because that is the elevation of my true south satellite (83w at 180.4) and adjusted the elevation on the dish its self to 45 deg to offset the elevation on the 45 deg mounting pole.
i then adjusted the azimuth on the mount on the pole in the ground and peaked the dish at 10.1 db sig to noise on my birdog.
by using a battery charger on the motor on the superjack actuator it allows me to rotate the dish.
it takes quite a bit of movement to loose 83w and i have yet to hit anything else by using the actuator.
i assume that my declination angle is off by a mile, but i'm not sure how to fix this because this is my first attempt at a movable dish.
any help would be greatly appreciated, as i am at a loss at how to get this to work, but in theory it seems it should, and it looks like it would.
here are some pix
thanks for any help,
Denny
here are some pix
Denny
