Anyone have a prefered diseqc switch they like?
I have been having switch issues lately and thinking of changing my coolsat switches out.
Me too...I got rid of the Chietas long ago, mainly because more that one switch was deaf on port 2. I have a Spaun, and it's a pretty good switch, but I have better c/n results with EMP Centauri switches.About a year ago I started work on a large switch matrix for feeding a bunch of dishes to multiple receivers. Prior to that time I had been using Pansat 4x1s because several vendors were tossing them into shipments for free. Given their reputation for ruggedness, I picked up a handful of the Chieta heavy duty 4x1s and started to use them instead of the Pansats.
But I immediately ran into minor losses in SQ and CNR. I ran some sweeps on my spectrum analyzer and every Pansat I tested was flatter across 950-2150 MHz than every Chieta. I didn't measure any other parameters, but that put a stop to the replacement strategy. I went back to the Pansats and they're working fine for me. It's possible that the Chieta switches are more rugged, but I'm not happy with their signal performance.
Meh, they don't care, they work with all of them. When I had a Diamond, it didn't care, either.
Meh?... Boy you sound like you're from Looziana. How goes it brother?![]()
I have used 1.00 switches, 5.00 switches, 10.00 switches, and 15.00 switches. They either work or they don't. A few guys like the Spaun switches, but bring your freshly-paid-off credit card, some of them cost as much as some cheap receivers!
DMSI use to have a good 4x1 with 3 ports on one side and 2 on the other. Then they switched to the "all on one side" theory and I blew a port in most of them
Oh, there is a bit of interesting information. I would have offered that I am a fan of the DMSI 4x1's, but that was before knowing they changed their design. Crap. Out of all the switches I've abused, those are the most rugged.
I just got some inexpensive Cheita switches (based on recommendations from a similar thread a few weeks ago). Turns out they're clones. They're working better than what I had. ... so far. I suppose I can live with it... I think what I've learned is that I should always have spares at the ready.
Limited time offer
