what size dish I need for c band Intelsat 9 | SatelliteGuys.US
nitos
USA
hello everybody what size dish I need for Intelsat 9 58.0 band C I live in las Vegas NV thanks for your help
any channel is specific?
Some are very strong and a 4 footer would work (like NHK) but some are very weak so you need a 10 footer
check out thelist at the top. Everything on 58W I picked up with a 6 footer in Minnesota
My 6' is normally parked on 58W and there is a ton of margin on all the signals. It's going to be lower on the horizon in Las Vegas than here in Denver, but as long as you have line-of-sight, you should be fine.
Pendragon or anyone else, what's a strong Ku Band transponder @ 58? the "strong transponder to aim dish" thread mentions this:
58 (PAS-9)-11612 H 3670 (Need a Universal LNB)
but I wanted a second option in case I cant get that one
maybe I can try to find the sat first while I wait for the C Band LNB
Since you live in Mexico you should try any SKY Mexico TP since they are on 24x7 just to check signal levels. Although as per Lyngsat there is a FTA TV channel named SKY View. The rest are feeds on CONUS beams and as you said it requieres a Universal LNB.
I get 58W C Band with a motorised 6 footer fine.
that TP is actually gone. I dont have a Universal LNB set up to see what is up there so if someone can scan 58W and send me the TP's active that would be great :)
Even if there is no channels that fine
nitos sorry for hijacking your thread with Ku Band info but here's what I found @ 58W (ill be PMing this info to Ice):
4 Sky Mexico TPs with over 100 channels but 99.99% of them are NDS Encrypted :( (as you can imagine the quality is booming for me using the 7 footer)
The 4 ITC channels are:
12179V 30000 Sky Mosaic 0512 0840 0512
11998H 30000 Sky Mosaic 0525 0853 0525
11978H 30000 Sky Mosaic 0525 0853 0525
12099V 28.300 Sky Prepago 0522 (Audio is AC3 I believe)
My crazy pansat 9200HD
New LNBF - only one wire?
