Nice job mounting the box with the 80-20
Hello "Mr. Red-Green" Dodge,
How's Harold?
I did make an error, though. The electrical enclosure box isn't mfg by Thompson, but by Hoffman.
You have a good eye.
RADAR
Could you elaborate a bit on having taps for each LNB output. What they're for, and how do you pick a tap to put on a particular LNB output? What tap makes and models you can suggest?
That is certainly true, if the dish photo is his!well considering that is a hacker he gets what he deserves![]()
In the switch test PDF, the author says "diseqc or multiswitch", which is suspect enough.
Then shows what looks like a DishNetwork SW21.
Whatever he's testing may catch some bad switches, but it's certainly not a test I'd waste time performing, nor relying on.
tvropro
What's that black piece of equipment shown on the front plan for, and how do you control it from your house living areas? It looks like a pretty big switchboard mounted on the wall behind it.![]()
Here's a picture behiind my rack. Total rats nest but hey it works
Any takers wanting to trace it? I have a good schematic of it all in my head.
I Sure Hope You Never have Any Problems back There![]()
I dont post links. I usually post what I knowAnyone can post solid content links or explanations and schematics addressing the following:
biggest multiswitch I have seen is a 17x16 which unless you have bandstacked LNB's is a 8x16 multiswitch. It would work with Diseqc 1.1 protocol (easiest) or Diseqc 1.2 which is a little more difficult.- How a large Multiswitch works from schematics standpoint - the one (with DiSEqC switch integrated?) having more than 6 Out ports to hook up LNBs?
very rarely would you cascade multiswitches in a FTA world unless you have some laying around. Most of the time just get a bigger multiswitch. The original reason for cascading switches was for DIsh/Direct/Bell/Starchoice.- How a Cascading Multiswitch works? What they're for, and how to setup correctly? In what kind of systems commonly used Cascading Multiswitches are preferred to a larger multi-LBN port Multiswitch?
you already posted a pic of one.- How to correctly combine commonly used Multiswitches with high frequency splitters connected btw them and (regular or bandstacked) LNBs? Advantages & Drawbacks? Splitter makes and models?
multiswitch and diseqcs....that is the easiest. Anole already posted pics of those setups- In what multi-receiver installations a cascaded mix of DiSEqC 4x1 and 22 KHz switches or splitter would be preferred to a Multiswitch matrix?
- Under what conditions using 8x1 DiSEqC Switches in a Single or Multi-Receiver installations becomes more rational than other choices?
Thanks Iceberg.This is my old switchbox.
Are you talking about the unit in front of the picture? Thats my 922.
Here is a quick shot I just took of my rack (excuse the slightly poor picture quality)
What memories this picture brought to me. I also had that plastic satellite dish LCD clock back in the 80's. I believe I bought it on Green Sheet.
Limited time offer
