Whats up with Sadoun ? | Page 2 | SatelliteGuys.US
Just got my... err.... wife's GBox yesterday. Works great and the wife loves it!
No more having to tell her what channel is on what sat and using the analog box to do the dirty work by hand.
Thanks Mr. Sadoun!:hatsoff:
Guess Sadouns phone is down again
Tried touching base to see if Sadoun had any info for me from contacting Motech. Got that crazy mailbox number again on both tel numbers. If you see this Sadoun you need to check into that again :(
Hi TVRO
The factory engineer indicated it could be a defective REED sensor or bad connection to sensor. I will send you a replacement sensor soon.
Hi TVRO
I looked at the sensor since I now have the arm in the house, it's sealed in plastic and the wires are soldered on so I can't see the contacts. It could be freezing because there possibly is moisture in the reed?
Do you need a copy of my original receipt? I could scan it and e-mail it to you. Let me know any information you need.
Thanks TvroPro :)
Telstar 11N's footprint to USA
C/Ku/IF Frequency Calculator/Converter
