How long did it take to come from Hong Kong? I place an order Nov 27 for a 7500.
I haven't got it yet or any shipping info.
I placed the order December 7th and received it today. I opted for DHL expedited shipping...costed about 11 bucks more but I wanted to see where it was. You should have got an email from Prof with a login and password when the order was processed.How long did it take to come from Hong Kong? I place an order Nov 27 for a 7500.
tell TransEdit the Prof is a TBS device and everything worked fine. I'm not sure what the relationship is between those devices?
I've been playing around with the Prof today and found I have no DiSEqC control with DVBViewer.
I'm getting old and forgetful, at least that's what my wife tells me. I had changed the transedit.ini to .0=13, but I forgot to change the version back to 3.5.1.0...now it works! ...at least what I can test as we got 14 inches of snow today and some of the dishes are full of snow.Re: TransEdit, are you using the latest 3.51.0? That one has been fixed so the Prof 7301 is recognized as vendor.0=13 in Transedit.ini. I'm also using Prof 7301 beta drivers 1.1.2.0
well its a simple question ? should i buy a BLSA or 3 prof cards and concentrate on the same drivers as this thread. im a year out of driver development but i would be willing to work on something useful. and i have a big hardon image of 35 of my BIG dishes all blindscanning s2 static. i need enthusiasm if anyone asks.
Actually, Montage DVB-S2 chipset has better published specs than the one above of STMicro.
I guess, the only way to find if something better already came along in terms of signal locking is for someone well equipped (in a broader term) to test the new DVBWord rigorously.![]()
Talking about particular specs you mentioned, the result also depends in part on how artfully a driver developer exploited known to him fine tuning programming options of a selected chipset, and where co-operation with the chipset manufacturer went to at that point of discovery of chipset weaknesses and improvement opportunities.
Limited time offer
