I am preparing to rotate the dish/wedge assembly 90 degrees on the mount, so I did some measuring and established some lines on the dish to orient the new holes I will need to drill.
Today, with the dish in bright sunlight I noticed that there is a very small line (seam?) on the long (vertical) axis of the dish, so I penciled that one in, the horizontal line was measured off of the existing studs (centered).
Once I get the dish/wedge rotated and installed on the mount I will have to get the dish face perfectly vertical, then measure the elevation bar, to determine the total of the offset that is created by the wedge and the built-in mount declination.
Then things will start to get interesting.........
