Let's petition DISH to change initial recording. | SatelliteGuys.US
getstuff4less
235
CA
Hello,
I think we should have DISH make it so that you go to the guide and make the DVR similar to DirecTV Press the record button once for a show then twice for a series. Setting the options ALL the time is the one thing I think could use some work.
What do you guys think?
Dish's DVR works great for me. If there were things I would implore Dish to change, your suggestion would likely be at the bottom of the list. I think the Dish DVR is far superior in terms of user interface and ease of use than any I have seen.
We might see this feature in a future software release
on the VIP series receivers. Anything is possible with software.
Pressing select TWICE does the trick. It automatically selects to record one time only if it is a movie and weeky if it is a series.
I don't care anything about this "new" that former D* customers seem to want. It works good as is now, it gives you more choice the way it is now.
For the record. I've never had (or personally used) DirecTV/DVR by DirecTV ever. I know it gives you more choice, but 99% of the time I select it to record only new episodes. Why not just not use it if you don't like it. I mean you have to admit if your in the guide and you want to record a show pressing record once to record it once or twice for all new episodes in the series is easier.
Having both DirecTV HR units and Dish Vip DVR's in my house, it is my personal opinion that Dish should in no way try to copy anything that DirecTV does when it comes to their DVR. Not unless they want to turn the worlds greatest DVR into a POS!
:up :up :up :up :up
Dishes DVR systems are just fine the way they are. They are not difficult to use and have worked just fine for 99 percent of the people I have installed. The only thing I would love to see Dish do is add a clock to the front of their receivers like some of the cable companies receivers have. Also would love to beable to change the EPG colors. The colors they use now makes it difficult for me to read them from a distance.
Making "new" the default for series might be nice, but I like the way it is now. I want to have the option of just an episode or all episodes ready and waiting.
I bet most of the time users select it to record a program once or all the new episodes in a series. Maybe, I'm in the minority, but having to delete repeats of the same episode gets annoying.
Select NEW from original air date/time and you won't have to.
I know, but they could easily make it so you have fewer clicks. They could have an option that says something like: "classic recording" ON/OFF? That way everyone is happy.
I agree about a choice for the colors, but.......
NO CLOCK!!!:D:D
Just switched to Dish: First impressions and a few questions
Using box somewhere else
