10/29/2009 3:15pm - Uplink Activity Report - 44 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 10/29/2009 3:15pm - 44 changes
Uplink Comparison Range: 10/28/2009 10:20P - 10/29/2009 03:15P
Channel Additions:
5184(20) - WTXX [MPEG4 HD] added to Echostar12 61.5W TP 01 Spotbeam 3 (A) (H)(Waterbury, CT-CW)
6363(50) - WDCW [MPEG4 HD] added to Echostar12 61.5W TP 05 Spotbeam 4 (A) (H)(Washington, DC-CW)
Channel Removals:
7384 - WTXX (A) (H) removed from Echostar12 61.5W TP 01 Spotbeam 3(Waterbury, CT-CW)
8074 - WDCW (A) (H) removed from Echostar12 61.5W TP 05 Spotbeam 4(Washington, DC-CW)
9899 - ITMP1 (NA) removed from EchoStar3 61.5W TP 18 ConUS beam
36610 - ACTVT (A) removed from EchoStar3 61.5W TP 14 ConUS beam
Channel Moves:
8115 - WMBC [MPEG4 SD] moved from Echostar12 61.5W TP 01 Spotbeam 3 to Echostar12 61.5W TP 07 Spotbeam 3 (A) (H)(Newton, NJ-N/A)
8116 - WRNN [MPEG4 SD] moved from Echostar12 61.5W TP 01 Spotbeam 3 to Echostar12 61.5W TP 07 Spotbeam 3 (A) (H)(Kingston, NY-IND)
406 - SETA [MPEG2 SD] moved from EchoStar3 61.5W TP 14 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A)
471 - SPORT [MPEG2 SD] moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A)
576 - ZEESA [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A)
583 - RADIO [MPEG AUDIO] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A) (H)
584 - SAMAY [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A)
585 - AAJTK [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A)
588 - BLUE [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
589 - ANTGO [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
598 - RBTI [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
599 - SICNO [MPEG2 SD] moved from EchoStar3 61.5W TP 29 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
604 - KINO [MPEG2 SD] moved from EchoStar3 61.5W TP 14 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
606 - BBCAR [MPEG2 SD] moved from EchoStar3 61.5W TP 14 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
613 - TVASA [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
617 - ZCINE [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A)
619 - B4U [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A) (H)
624 - SHARA [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A) (H)
643 - ARTMV [MPEG2 SD] moved from EchoStar3 61.5W TP 10 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A) (H)
652 - KBS [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A) (H)
665 - ZIKR [MPEG AUDIO] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A) (H)
673 - MZIKA [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A)
767 - ABUDA [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A)
769 - DREAM [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 29 ConUS beam (A)
778 - NBN [MPEG2 SD] moved from EchoStar3 61.5W TP 14 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
779 - NEWTV [MPEG2 SD] moved from EchoStar3 61.5W TP 14 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
914 - NT105 [MPEG AUDIO] moved from EchoStar3 61.5W TP 14 ConUS beam to EchoStar3 61.5W TP 29 ConUS beam (A)
915 - ERA-5 [MPEG AUDIO] moved from EchoStar3 61.5W TP 14 ConUS beam to EchoStar3 61.5W TP 29 ConUS beam (A) (H)
9620 - BTV [SD TV] moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A)
9621 - BTV [SD TV] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A)
9622 - BTV [SD TV] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A)
36853 - DNL12 [143] moved from EchoStar3 61.5W TP 29 ConUS beam to EchoStar8 77W TP 29 ConUS beam (A)
36854 - DNL10 [143] moved from EchoStar3 61.5W TP 29 ConUS beam to EchoStar8 77W TP 29 ConUS beam (A)
Channel Package Flag Changes:
9640 - WFTV [SD TV] - EchoStar9 121W TP 15 ConUS beam changed to Available(Orlando, FL-ABC)
Channel Renames:
5659 - KFVE - EchoStar10 110W TP 23 Spotbeam 47 renamed to KGMB (A) (H)(Honolulu, HI-MY)
5671 - KGMB - EchoStar10 110W TP 23 Spotbeam 47 renamed to KFVE (A) (H)(Honolulu, HI-CBS)
8901(9) - KFVE - EchoStar7 119W TP 09 Spotbeam 1 renamed to KGMB (A) (H)(Honolulu, HI-MY)
8904(5) - KGMB - EchoStar7 119W TP 09 Spotbeam 1 renamed to KFVE (A) (H)(Honolulu, HI-CBS)
Channels in the system: 6620
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
I am hoping that the 8 TEMP HD Channels are...
TCM HD, AMC HD, EPIX HD, BBCA HD, IFC HD, Sundance HD, QVC HD, HSN HD,
You can expect any of them to come in "bunches"
AMC/IFC/WE/Sundance- unlikely because of the lawsuit, but it would be a package deal. Also, probably Fuse, though they are under different management.
BBC/ID
E!/Style/G4
TCM/TruTV
...and so on.
BBC/ID
E!/Style/G4
TCM/TruTV
...and so on.
Don't forget HLN with the Turner group.
As for my guesses (since people seem to be guessing in this thread):
ESPNU
BBCA
Investigation Discovery
QVC
Epix
E!
Style
G4
I still would be unhappy with a lack of Outdoor, TCM, HLN, and IFC. AMC and Hallmark would be nice, too.
Over the next year they will add a lot of WBs/PBSs etc. They have to get another 25% of the markets they carry in HD to have all the channels in the market HD. The first 25% was pretty easy when there were a ton of small markets with only the big 4. I suspect now all the markets with just +1 or +2 more channels will get added to make the 2010 quota.
This should be VERY easy to do on the 129 HD markets. Most of the time each market has a TP to itself. Plenty of room in there especially with some of the HD channels in the market having low bitrates to begin with a few subchannels thrown in their OTA mux.
WB network is not doing well finacially. I would be surprised to see it go under or sold in a year or two. CW hd is another story. Bring it on to my neck of the woods!!
D
10/28/2009 3:15pm - Uplink Activity Report - 119 changes
D
11/4/2009 4:40pm - Uplink Activity Report - 98 changes
