LNB drift = bad LNB. Get it replaced.
LNB drift is not an issue anymore unless you have legacy rcvrs. Dish Pro rcvrs and Dish Pro Plus rcvrs, basically anything that is not a 4 digit rcvr like 2900 or 4000, has software that searches an unlimited frequency variation for each channel. this is built into their software now, so if you have signal problems check the regular line of sight or alignment
So your saying if you have say a VIP722 drift will not be an issue but will show up on the info screen? I never realined the dish and my line of sight is good. But after the reboot the -7 drift went away after putting on a new LNB. a little Confused here. Was talking to an installer and he said he has never heard of anything like what you said
Mine was reading an LNB drift of -8 on 129. An installer came out to deliver a 722K to me and when he was here I told him about the LNB drift. I assumed the 129 LNB was bad so he changed it. The LNB drift reading remained so he changed out the dual LNB for 110/119. Once he did that the LNB drift reading disappeared. You might need to change another LNB even though it's indicating the 61.5 location. The installer said he thought it was probably the switch in the 110/119 dual LNB which the 129 LNB plugs into.
He's saying it's a non issue. That the tuners now can follow the "drift" of the LNB.
Great discussion, thanks for all the feed back. I am now educated. But one last question. What is drifting? Is the LNB moving? Is the satilite moving and the LNB cant track it? Or is it an electronics issue. The LNB is warm to the touch and heat kills electronics.
If that was true, then why have I arrived on many trouble calls where customers have a SuperDish and the problem is LNB drift? The LNBs on the SuperDishes often drifted creating many problems for customers with Dish Pro and Dish Pro Plus receivers. Once we replaced the SuperDish with a Dish 500, everything was back to normal.
Limited time offer
