722k uhf tv1 remote | SatelliteGuys.US
722k uhf tv1 remote
the mack
1,479
483
HOCKEYTOWN
I would like to use a uhf pro remote to control tv1 on a 722k, do I need the tv1 key to use in a uhf 6.3 remote? and if I can use uhf pro will the ir remote still work.
tia
tia
You will need to use your TV2 remote, since the TV1 that came with the receiver is IR only, and flip the key so that the green #1 is showing. Go into the system info screen by pressing menu twice and press the record button. Your original IR TV1 remote will no longer work since the remote is now specified as IR/UHF instead of just IR. If you get another UHF enabled remote you can program that one for TV2.
The original IR remote WILL still work, as I'm using both IR and UHF on my 622 TV1. Secondly, if you flip the blue chip on a 6.3 remote, you will get the (old style) black UHF key.
Good News
Web Site Reciever Question
