Scott, need VIP-922 dimensions | SatelliteGuys.US
Just a thought. You don't want to pack in any DVR into that tight of a space. It will overheat for sure. Make sure there is excellent room all around it.
It is the same height as a 722k, just under 3.5in high (just talked to my dealer friend). But again, I would not stuff it into a small space or you are going to regret it.
I haven't gotten home the past few nights until after 11pm. I will try to measure it tonight as only thing I have tonight is my sons football practice.
Why do you think he/she is going to build a space that's just bigger than the unit itself ? In order to make the space for it big enough, he/she has to know where to start.
Because in general all the recent DVR receivers are the same height (942, 622, 722, 722k, 922 are all within a 1/2 inch of each other) the fact that the poster wants to know exactly how high it is worried me as I am afraid they are going to put the receiver in too small a space. Just trying to prevent a problem before it happens. :)
Trying to help you here. I think it might be the same size as the VIP 722.
From the pictures, it appears to be in the same box as the 612 and 722K. The 622/722 is a different box. They are all around 16-17" wide, but shouldn't be put on a shelf less than 20" wide, nor should they have a pocket shorter than 6" tall to call home. Blocking the front or rear of the pocket is also unacceptable; these bad boys need to BREATH.
Maybe he's trying to stuff it into a small fridge to keep it cool and doesn't want to buy one too small for it to fit, nor too big to waste space. :)
disable inactivity mode
Dead HDMI replacement
