Can anyone tell me if RTN east/west is working right now.
7:30pm eastern.
I have scanned for it 2 times now and it is not showing up.
7:30pm eastern.
Did you use USALS or DiSEqC 1.2? That is, if you used your motorized system...Thanks Ice...
I have just switched over to a 5000 also after all of the recomendations from this site.
So I may be a bit rusty on the settings. I believe I have them all good. Did not pick it up after the first scan, so I manually punched in the tp (11735 I think)and all I get on AMC 9 @83W is an NBC news channel (AMC9/3F) with bars showing.
Not much! A couple of millimeters is all it takes. I'm wondering if you need a lift or a drop in elevation, as a guess. My fathers was off East-West by loosening one nut-side and tightening the other two by half a turnHow far can I be off if I have 90% on the other channel?
tried moving it over both east and west and there is no change to the 'Q' scale.
Yes.When you say "4440"....
on the Coolsat 5000 it is entered as 4.440 (MS/s) correct?
correct 4.440
No joy here with 4560. But it was fun trying.In my thread of a few weeks ago concerning the RTV signal, another member (sorry, I can't remember who) suggested that I try an SR of 4560. Yes, that number seems strange, but my signal strength jumped from the mid 40s up to the high 60s and once in a while in the low 70s. The problem I have, along with others is low or no signal between about 9 and 11am eastern.
Anyway, give 4560 a try and see if it helps.![]()
Ive been trying over an hour to put these setting in my Coolsat 5000. When i put 11735 in "frequency" it says invalid frequency. What am I doing wrong?
thanks
especially considering its a H transponderThe RTV (formerly RTN) transponder (11.735 Vert symbol rate 04.444 MS/s) on AMC 9 @ 83.0W can be a bugger!
Limited time offer
