Hard Drive Bargain Watch | Page 30 | SatelliteGuys.US
It was multi LUN enclosures limit, ie with two or more physical disks inside.
C'mon - we corrected this "platter" error many times.
Yes, you are quite correct. I put fingers in motion prior to fully engaging brain.
However, the question remains - not all 1.5TB will work, and how do you know which will?
I tried a Seagate Freeagent 2TB EHD on my 622 today...it only formated 1TB of disk space.
Which 1.5TB are known to work if it will only formate the 2TB to 1TB?
You probably have a EHD with 2 drives instead of one. If the EHD is wider than around 2 inches, this is probably the case. They don't work properly.
DVR percent meter issue
No signal Port 4 External LNB
