Menu select preferences and them inactivity standby and so on....
That explains why I didn't have that problem this morning. For years, with Primestar, DirecTV, and various cableco's, the TV coming on has acted as our alarm clock. Had Dish installed Monday, and Tuesday morning a nice quiet screensaver came on. Last night I figured out how to deactivate it, and also set an "Auto Tune" timer for our preferred wake up program. Came on like I wanted it to. Glad I hit the right combination right out of the box.Even if you have the inactivity deactivated, the box will still perform its "Daily Update" system check (essentially a re-boot, short diagnostic, check for latest firmware, and download of guide data, each day at either the default 3AM time or any other time that you chose, but you cannot deactivate this feature. After the "Daily Update" completes, the box will display the screen saver.
The only workaround on this is to set an "Auto Tune" timer for about 10-15 minutes after the scheduled "Daily Update" for the box to return to displaying video. If there is a DVR timer set to record at or during the time for "Daily Update,s" The "Daily Updates" will be canceled/postponed so that you will not miss a recording.
Hi, Thanks for your reply. I have the inactivity stadby disabled already, but the screen saver keeps turning on. Am I doing something wrong?
What are you trying to achieve? That might help us help you.
Limited time offer
