looking for parts for a 39" wingard dish? | SatelliteGuys.US
I've just drilled a new hole between and just in front of the other two holes to put a new holder on mine. I drilled it just far enough ahead of the other two that the it wouldn't end up making a slot out of the original two. I used a small bit to create a tracking hole to keep a larger bit from wandering, then a bit large enough for the screw to fit.
QUESTION ABOUT SATMEX5
LNB FAQ
