8/5/2009 12:44pm - Uplink Activity Report - 64 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 8/5/2009 12:44pm - 64 changes
Uplink Comparison Range: 08/05/2009 12:29P - 08/05/2009 12:44P
Channel Removals:
4786 - WJSU (A) (H) removed from EchoStar7 119W TP 09 Spotbeam 12(Anniston, AL-ABC)
4787 - WIAT (A) (H) removed from EchoStar7 119W TP 09 Spotbeam 12(Birmingham, AL-CBS)
4788 - WVTM (A) (H) removed from EchoStar7 119W TP 09 Spotbeam 12(Birmingham, AL-NBC)
4789 - WBRC (A) (H) removed from EchoStar7 119W TP 09 Spotbeam 12(Birmingham, AL-FOX)
8304 - WATL (NA) removed from Echostar12 61.5W TP 15 Spotbeam 6(Atlanta, GA-MY)
4782 - KOCO (A) (H) removed from EchoStar7 119W TP 03 Spotbeam 9(Oklahoma City, OK-ABC)
4783 - KWTV (A) (H) removed from EchoStar7 119W TP 03 Spotbeam 9(Oklahoma City, OK-CBS)
4784 - KFOR (A) (H) removed from EchoStar7 119W TP 03 Spotbeam 9(Oklahoma City, OK-NBC)
4785 - KOKH (A) (H) removed from EchoStar7 119W TP 03 Spotbeam 9(Oklahoma City, OK-FOX)
4778 - KTUL (A) (H) removed from EchoStar7 119W TP 01 Spotbeam 9(Tulsa, OK-ABC)
4779 - KOTV (A) (H) removed from EchoStar7 119W TP 01 Spotbeam 9(Tulsa, OK-CBS)
4780 - KJRH (A) (H) removed from EchoStar7 119W TP 01 Spotbeam 9(Tulsa, OK-NBC)
4781 - KOKI (A) (H) removed from EchoStar7 119W TP 01 Spotbeam 9(Tulsa, OK-FOX)
6802 - UP2 (NA) removed from Ciel-2 129W TP 18 ConUS beam
6805 - UP4 (NA) removed from Ciel-2 129W TP 32 ConUS beam
6809 - UP4 (NA) removed from Ciel-2 129W TP 14 Spotbeam 27
6811 - UP4 (NA) removed from Ciel-2 129W TP 01 Spotbeam 18
6816 - UP5 (NA) removed from Ciel-2 129W TP 03 Spotbeam 25
6817 - UP5 (NA) removed from Ciel-2 129W TP 08 Spotbeam 25
6818 - UP5 (NA) removed from Ciel-2 129W TP 11 Spotbeam 5
6819 - UP5 (NA) removed from Ciel-2 129W TP 09 Spotbeam 42
6824 - UP6 (NA) removed from Ciel-2 129W TP 15 Spotbeam 52
6825 - UP6 (NA) removed from Ciel-2 129W TP 01 Spotbeam 47
6827 - UP6 (NA) removed from Ciel-2 129W TP 04 Spotbeam 52
6829 - UP6 (NA) removed from Ciel-2 129W TP 13 Spotbeam 6
6830 - UP6 (NA) removed from Ciel-2 129W TP 09 Spotbeam 36
6831 - UP7 (NA) removed from Ciel-2 129W TP 11 Spotbeam 36
6832 - UP7 (NA) removed from Ciel-2 129W TP 12 Spotbeam 30
6833 - UP7 (NA) removed from Ciel-2 129W TP 16 Spotbeam 36
6835 - UP7 (NA) removed from Ciel-2 129W TP 14 Spotbeam 10
6837 - UP7 (NA) removed from Ciel-2 129W TP 03 Spotbeam 37
6838 - UP7 (NA) removed from Ciel-2 129W TP 07 Spotbeam 12
6839 - UP8 (NA) removed from Ciel-2 129W TP 08 Spotbeam 12
6842 - UP29 (NA) removed from Ciel-2 129W TP 11 Spotbeam 22
6843 - UP29 (NA) removed from Ciel-2 129W TP 16 Spotbeam 23
6844 - UP29 (NA) removed from Ciel-2 129W TP 02 Spotbeam 43
6845 - UP29 (NA) removed from Ciel-2 129W TP 04 Spotbeam 19
6846 - UP29 (NA) removed from Ciel-2 129W TP 15 Spotbeam 19
6847 - UP29 (NA) removed from Ciel-2 129W TP 06 Spotbeam 43
6857 - UP29 (NA) removed from Ciel-2 129W TP 02 Spotbeam 17
6860 - UP29 (NA) removed from Ciel-2 129W TP 13 Spotbeam 38
6865 - UP29 (NA) removed from Ciel-2 129W TP 09 Spotbeam 44
6875 - UP29 (NA) removed from Ciel-2 129W TP 06 Spotbeam 19
6879 - UP29 (NA) removed from Ciel-2 129W TP 10 Spotbeam 35
6882 - UP29 (NA) removed from Ciel-2 129W TP 03 Spotbeam 21
6896 - UP29 (NA) removed from Ciel-2 129W TP 12 Spotbeam 7
6917 - UP29 (NA) removed from Ciel-2 129W TP 16 Spotbeam 14
6941 - UP29 (NA) removed from Ciel-2 129W TP 16 Spotbeam 10
6943 - UP29 (NA) removed from Ciel-2 129W TP 15 Spotbeam 10
Channel Package Flag Changes:
5261(10) - KTVL [MPEG4 HD] - Ciel-2 129W TP 16 Spotbeam 10 changed to Available (H)(Medford, OR-CBS)
613 - TVASA [MPEG2 SD] - EchoStar3 61.5W TP 18 ConUS beam changed to shown in non-sub's guides (A)
788 - TVASA [MPEG2 SD] - Anik F3 118.7W TP 22 ConUS beam changed to shown in non-sub's guides (A)
860 - AMRCA [MPEG4 SD] - EchoStar10 110W TP 29 Spotbeam 49 changed to Available (H)
904 - TVONE [MPEG2 SD] - Anik F3 118.7W TP 24 ConUS beam changed to Available
Channel Renames:
14525 - WHIQ1 - EchoStar10 110W TP 31 Spotbeam 11 renamed to WHIQ2 (NA)
14034 - WTTW1 - EchoStar10 110W TP 31 Spotbeam 19 renamed to WTTW2 (NA)
14659 - WPTO6 - EchoStar10 110W TP 23 Spotbeam 10 renamed to WPTO2 (NA)
202 - HNN - EchoStar10 110W TP 29 Spotbeam 49 renamed to HLN (A) (H)
202 - HNN - EchoStar7 119W TP 19 ConUS beam renamed to HLN (A)
202 - HNN - Echostar6 72.7W TP 11 ConUS beam renamed to HLN (A)
9645(99) - SWEET - EchoStar11 110W TP 10 ConUS beam renamed to LF1 (A)
9645(99) - SWEET - EchoStar8 77W TP 29 ConUS beam renamed to LF1 (A)
Transponder Changes:
EchoStar7 119W TP 09 Spotbeam 12 21500 8PSK 2/3 removed
EchoStar7 119W TP 01 Spotbeam 9 21500 8PSK 2/3 removed
Channels in the system: 6609
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
They forgot to change the free preview channels,
GAC and WFN were supposed to be taken out of free preview, and SoapNet was supposed to be added as a free preview.
Digi, there must be something odd going on with the flags. Not only does it appear in my guide, it shows as available. Did it go into preview mode simultaneously and get missed somehow? (I have no international subscriptions at all, and thus can't check the version on the 118 bird.)
It is a free preview channel. I'll check to see this channel change today and see if I need to modify the wording/logic of some things on this type of flag change.
TP 21 on Sat 61.5
Hello Digiblur
What's up with TP21 on sat 61.5. There is good signal strenght on that transponder but nothing beeing transmited on it. Don't know what are the plans for it, sinse they moved all those channels on that TP to Sat 110. Maybe planing on adding some more HD's?
D
8/6/2009 4:54pm - Uplink Activity Report - 1 change
D
8/13/2009 2:14am - Uplink Activity Report - 6 changes
