Thanks! I "think" I can do a 3 lnb with no problems. I assume it would be similar to a Dish 1000, where you set it up to the middle sat and the others fall in place.
Its too bad you can't try it first, and then let the pros do it if you run into trouble. But they most likly won't like that.Well I just watched the install videos on solid signals and it has me scared off! Power inserters, alignment switches, all kinds of gadgets needed to install. YIKES! I think I will let the pros install it![]()
Since the first few posts were way off the mark (starting with the reply about DISH Network equipment and moving right through the insistence on where locals come from)?uh why attack hemi just out of curiosity?
That's the wonder of DIRECTV's current system. It really doesn't matter what the subscriber wants, they get what DIRECTV says they get unless they go through a dealer. Self installs are very much discouraged by DIRECTV.also, you didnt read what the OP wrote...I'll even bold it so you can see it
Try reading the other posts in the thread next time. You could plainly see You and others weren't correct either. If I want to post in the D* sight to help a fellow Pub Member thats the right I pay Yearly for. But it looks like your not correct on where his locals come from either. It was Already stated by an Installer what setup to use.Since the first few posts were way off the mark (starting with the reply about DISH Network equipment and moving right through the insistence on where locals come from.
If you look closely, I was the one that pointed out where the locals actually come from and that the Slimline would likely be part of the installation. The single element that I may have been mistaken about was the dual dish thing, but I didn't want to assume that the OP was going to install suitable DVRs given that they said specifically that they were getting SD DVRs (and R22 DVRs have been an on-gain off-again thing of late).Try reading the other posts in the thread next time. You could plainly see You and others weren't correct either. If I want to post in the D* sight to help a fellow Pub Member thats the right I pay Yearly for. But it looks like your not correct on where his locals come from either. It was Already stated by an Installer what setup to use.
Slimline!
You should take your own advise.:upHaving a subscription or membership doesn't absolve you from researching your "advice" as opposed to noodling out loud and refining your answer as you bump into walls.
Sorry.knock it off guys.![]()
That would be cool, Let us know what happends either way.:upTHANK YOU for all he replies! Sorry for any mess I causedWill keep you posted if my attempts are sucessful!
If Larry is the same way with this install as his original FTA install, we'll get blow by blow commentary on the install![]()
Limited time offer
