722k Unwanted Screen Pop Up | SatelliteGuys.US
Frank Jr.
Beati pacifici 5:9
13,831
1,912
Columbia S.C.
Not a major issue by any means but every now and then I get this screen to pop up on both my 722k's. Anyone else have this issue? I know what I am watching. Sorry about the quality of the picture but I was in a hurry. Is there a setting in the menu to stop this?:confused:
Yep it pops up all by itself. I think I will remove the uhf antenna on both of them. Not using it anyway. Thanks Guys, Very Much! We shall see. That's what the blind man said anyway.:D
you should also change your remote address like hifi mentioned. any neighbors that have dish?
No one I know of, maybe across the lake but that would be a stretch!;)
I thought about that OTA thing, but both receivers and they are on different addresses? Could be I guess. I'll take the antennas off and see what happens. Thanks again.
I've had this happen with 622, 722 and 722k usually when using the TV2 remote. I think there is something "close" in the guts of the remote to another button that registers a press when not actually happening.
I think the issue is caused by the remote. It is firing all by itself on that one issue. Just that one screen. Think about it........Makes sense:confused:
I have a 722 and I have the info screen pop up all the time also. I am using the Logitech 880 remote. I have tried changed the UHF address, removed the UHF antennae, removed the batteries from my UHF remotes, and I still get the pop-up. It is very annoying.
I am using the all-in-one that came with my Onkyo reciever. Original remotes stored in original shipping bag, with no batteries in them at all. Also all RF-Functions disabled, and I don't have the antenna attached to the receiver either.
Yet I still get this annoying popup as well.
Though still not as annoying as the audio randomly cutting out, requiring a reset to resolve. (Sometimes not so easy to do though since there always seems to be something taping, when I notice the audio issue)
HD Tuesday Roundup
More Help Finding 61.5 or 129
