This is a great site!! | SatelliteGuys.US
J-V-D
17
Michigan
I recently purchased a Geosat 36"Dish,GSL1u-Bullet LNBF,SG2100 H-H Motor.Installed it all and spent a couple days getting everything right and all the Scanning done.I am now viewing lots of progaraming on 14 different birds!!Just wanted to Thank all of you guys on this site for all the posts and usefull info!I am also lookind into circular/linear Lnbf's.Suggestions would be apreciated........P.S.....I am using a Captiveworks cw800s,and it seems to "BLINDSCAN" very well.Just thought I'd throw that out there since I have read that CW is only good for Pirating signals!...............Thanks again:up
I'm a NASA TV junkie during shuttle missions. My C-Band dish is stationary and not pointing at the NASA birds 72.0°W AMC 6 or 137.0°W AMC 7. So I added a circular LNB for the NASA TV signal that is in the clear on 119.0°W EchoStar 7. That's really all I use it for but it works great.
Back to the countdown for STS-127. ;)
glad its working out for you :)
very good to know. I have a 600 and I know the blind scan is pretty worthless ;)
now stay that way!!!!;) except for the occasional bone dish network throws us, circular is useless besides helping align elevation on a joint use bird
I thought that AMC4 and a few other sats had a circular signal on some FTA Transponders ?Does Lyngsat or any other site tell you which transponders are linear or circular? Thanks
If you click on the frequency information on each sat from the list there, it'll tell you whether its circ or linear on the left column. You can see transponder freq and polarization, i.e. L or R for left or right circ, and H or V for horiz or vertical (linear).
So I really dont need a dual circular/linear lnb like Invacom.....or will more be going cirular polarization in the future. Also teh Invacoms are listed at 0.3db where others are 0.4db.
The one drawback of the Invacom is it is very heavy so unless you have some support arms on the dish it may weigh down the dish which can hinder reception
I just hoseclamped a DBS LNB next to my KU LNB and its worked fine for 4 years now :)
The Invacom Quad is also very expensive, but it is a great LNBF and worth the money if your dish can support its weight. I have one on both of my motorized dishes, and they work like a charm :)
Thanks Turbosat,That is good to know.
So if i mount a cirular LNB and run both LNB'S into a SW21 or DiSEqC switch I should be good?......I have an Dual output Marked BSS 12.2-12.7GHz,950-1450MHz.Will that work?.I also have a Dish N single If that would be better?..Thanks J-V-D
depending on your KU LNB and what shape it is, some DBS LNB's are easier to mount on there
I have a Sadoun dual which looks like a "block" LNB...the DirecTV DBS rests right next to it and a hoseclamp holds it together
The attached pics are when I had a Universal (for IS9 58W), the standard and a DBS....the Universal has since been removed
Mine is one of those little geosat bullet lnb's, very small.I might try to make a mount for it to attach to the support arm?
ONN
Pool fence and dish farm
