iPhone ring tones | SatelliteGuys.US
iPhone ring tones
Try this one. Free registration, although to get the tones on the phone requires a little bit of workaround.
I wonder if you could just load MP3 tones on the phone and have it recognize them as ringtones. Anyone know?
If you have a mac it's very easy with garage band. you can import any mp3 into itunes and convert to aac , then import into garage band and edit anyway you like. then export back to the ring tones folder in Itune. It's been awhile since I did it but I think there is a lenght limit on the finished ring tone, maybe 20-30 seconds, but I'm not sure.
I've got a few that are several minutes long, all I did was rename a file from .m4a to .m4r and add it to the folder. Of course, nobody will let the phone ring long enough for me to hear the whole thing :)
i used the "rename" function in windows to do it :) Make sure to unhide "known extensions" first then just click the thing and rename it.
I've read there are some technical differences between a "standard m4a audio file" and a "m4r ringtone file" - something regarding metadata - but every one I have tried just renaming has worked fine.
Here is what I get when I try this. It doesn't look the same as the link video shows or describes. None of my MP3 files have the "m4a" in the file name, and when I convert my 30 sec clip to an AAC format to rename it to a "m4r", the file shows up as unrecognizable. What am I doing wrong here?
Should I upgrade my Iphone 3g to 3GS?
Apple kicks another app to the curb
