Superdish for 101 ( AMC 4 ) | SatelliteGuys.US
acuevas
SatelliteGuys Guru
132
Orange County
Hey All,
I'd likwe to explore the open channels on sat 101. Can I use a Superdish with center LNB ( is it universal? ) to view this sat? Thanks.
since the OP mentions AMC4 moving to free to air area
yes the SD wll work with most signals. Do a search in the FTA area and there are lots of threads on using a SD for AMC4 or other linear satellties
There are two kind of SD: SD105 and SD121, which one you have ?
Anyway, find that LNBF with letter "FSS" and connect your coax to it. Remember it is banstacking LNBF, so LOF2 is not 10750 but 13850.
"Orange County" in New York, or in southern California? - :cool:
I have only seen SuperDish 121's on the west coast.
Anyway, find that LNBF with letter "FSS" and connect your coax to it. Remember it is banstacking LNBF, so LOF2 is not 10750.
I have a SD121 and the middle LNB is FSS. But, I am not sure what you mean by your notes in second paragraph.
Correct
the FSS LNB is always on one end and is the one that is right down the arm of the dish. There should be a coax for "FSS" or the LNB will say FSS when you take off that cover
"one legged idiots with the patch over their eye"
Sadoun Hat
