EBAY FEEDS A question for Scott | SatelliteGuys.US
Cadsulfide
1,305
Cavalier, North Dakota
Scott;
Is there an easy way to exclude the new EBAY feeds from a new posts selection? I went to new FTA posts this morning, and found 260 EBAY ads comingled with the regular stuff. Kinda like looking for a needle in a haytstact.
Regards;
Scott R:)
In your User CP, Edit Options under Settings and Options. At the bottom is an exclude box selection box for all the forums.
yep. I just tried that and it works fine
user cp
edit options
select the ebay forum
save
then when you say "new FTA posts" those are excluded
A little help here. I tried the trick quoted above and it seemed to work on the first day or so but lately when I chose "new FTA posts" I get a few new FTA posts and pages and pages of ebay listings. How do I make the ebay stuff disappear for good?
The Ebay feeds are still a work in progress.
I am going to change them to make them so that if you want to see it you need to opt in instead of opt out.
I am also narrowing down the feeds today to search by model number as I posted over the weekend. This will cut down the feeds and only find models that people want to get their hands on cheap. :D
FTA receiver with built in positioner??
Going "GREEN" with a FTA system and saving "GREEN"
