is it possible to build someting i can run a coax from the lnb input to some kind of box, then run a coax to my dish, the module would then have a 3 wire terminal to run a polorizer with a pot to control the skew
Yes, those are much better than one that don't.i like lnbs with polorizers, skew changes with arc travel
It shouldn't change much. If I would do an auto-tune on any sat across the arc, it would generally end up with the same result. Can't do auto-tune on many sats anymore though, since not as many analog channels up there.i like lnbs with polorizers, skew changes with arc travel
EDIT: Removed comment about Self Leveling Feedhorns.
if you have a small dish, you can adjust the skew say a 36" er, but on a 10 foot dish, moving the feedhorn everytime you move, gets a little tiresome
That Drake should store every sat individually. ....
Agree totally here. The LNBF is the best thing for me.Yes..........but..........if your dish is properly tracking the arc.....yours IS properly tracking the arc, isn't it Techfizzle?.........then it should not be an issue.
I prefer a LNBF on my current setup because it's easy, there are less wires to run and it's one less thing to worry about failing. I think THE most common problem I've had in 17 years of owning and repairing C-Band systems is the polarotor.
This does pretty much hold true for C band analog, but as finicky as a digital signal can be, it's been my experience that a polarity tweak to a digital tp can yield a bar or two on the graph, and might make the difference in weathering a thundershower or even getting a lock or not on a marginal signal. I dont have an S2 setup, but I suspect it would help there too. Add a dual band C/Ku feed on a Bud and a continously adjustable skew for the Ku side is definately a must for maxing the available signal. This is already presuming a correctly tracking setup, as I can see 55.5 to 137 and all points in between. (I have a line of trees ~50ft high appx 60' east and south of my BUD. I can only see 55.5 and 58 when the trees are bare in the winter.)If you're having to tweak skew every time you drive the dish to a new position, something is horribly wrong. A properly adjusted C-band dish will track the Clarke belt very accurately, and since the LNB 'skew' should be in-track with the arc, there is nothing to adjust, other than for an oddball satellite like 103W on Ku. If the polar mount declination is set correctly, the skew will not vary more than a tiny fraction of a degree from perfect. You can't set it as accurately as it can be held.
Someone already posted a link to the forum thread, but here's a link to the website (so you don't have to read the whole thread, which is mostly me being confused about what I want to do) for what I made. It's exactly what you've described...
Polarotor Servo Controller
Now I'm working on what I call the "Priority Picking Polarity Controller" which allows the servo to be shared (good manners) among multiple receivers.
Limited time offer
