Did the Scoreguide Disable Your Yellow Button Menu | Page 2 | SatelliteGuys.US
Did the Scoreguide Disable your yellow button menu on the sports channels?
  • Total voters
    33
OK here's the deal. If I hit the red button it comes up. Then if I make the mistake of hitting exit its gone until I leave that channel and come back to it and press the red button a couple of times. yellow button works no matter what.
Yeah...The exit button always exits the interactive features permanently while on that channel; this has always been the case. I actually like this because you can choose to get rid of it while on that channel.
If you switch back to the channel after going to another one, it will come back.
If I was told this information before the feature was installed it would not have been such a big deal for me. I blame D* for not providing their customers this information.
With the exception of Hemi (which probably works now), every issue of those that posted are those whom have an H2x. Those of us without any issues all own an HR2x.
Is this something that only affects the HD receivers?? I have the SD receiver (so I can't answer the poll).
We are trying to figure out what receivers that have the Scoreguide feature disables the yellow button menu. So, if you can report your experiences we would appreciate it very much.
The exit button does not exit the interactive feature (TV Options Menu) permanently while on that channel.
So, the exit button only exits the interactive feature (Scoreguide) permanently at this time.
Alright , My Hr20 is up and running as it should.
My h21 though isn't working with MRV option. I think the software didn't download.
So now what?
But anyway My Yellow button is working on my HR20, But Not on my h21.
So now what?
When you can PM me the version of the software on your H21.
So now what?
i sent you a pm in response to yours. if you need further help just PM me :)
Anyone heard of a terminated dealer getting reinstated?
Do I need a multi-switch
