3 351cj Member Original poster Apr 9, 2009 6 0 Fairmount Apr 20, 2009 #1 For some reason on HD the sound is off from the actual viewing picture. When I turn it to sd, everything fine, HD, sound off. Any thoughts or ideas?
whatchel1 SatelliteGuys Master Sep 30, 2006 9,098 51 Great High Plains Apr 20, 2009 #2 Sync 351cj said: For some reason on HD the sound is off from the actual viewing picture. When I turn it to sd, everything fine, HD, sound off. Any thoughts or ideas? Click to expand... Is this true for all or just a few. If it is all try menu 6-1-7 and see if the sync is set for SD. If so then that is the problem.
G garys SatelliteGuys Master Sep 29, 2005 7,621 37 Greentown, Pennsylvania, United States Apr 20, 2009 #3 Try a hard reset. Sounds like a software glitch.
3 351cj Member Original poster Apr 9, 2009 6 0 Fairmount Apr 22, 2009 #4 whatchel1 said: Is this true for all or just a few. If it is all try menu 6-1-7 and see if the sync is set for SD. If so then that is the problem. Click to expand... OK, I tried the 6-1-7 and that didn't work. I notice it most when the family sits down to watch American Idol. It's not off really bad, but, like maybe a half second. But, noticeable. Thanks, Chuck
3 351cj Member Original poster Apr 9, 2009 6 0 Fairmount Apr 22, 2009 #5 garys said: Try a hard reset. Sounds like a software glitch. Click to expand... Hard reset meaning pushing the power button down for 10-15 seconds? Thanks, Chuck
Jim5506 SatelliteGuys Master Pub Member / Supporter Lifetime Supporter Oct 19, 2004 8,408 4,013 Slaton, Texas Apr 25, 2009 #6 Hard reset is pull the plug for 1 minute.
G garys SatelliteGuys Master Sep 29, 2005 7,621 37 Greentown, Pennsylvania, United States Apr 25, 2009 #7 351cj said: Hard reset meaning pushing the power button down for 10-15 seconds? Thanks, Chuck Click to expand... This is known as "Soft Reset". "Hard Reset" is pull plug for about a minute, as Jim said.
